YBF site Java Script Editor code has been modified.
http://forums.y-blocksforever.com/Topic22169.aspx
By Ted - 16 Years Ago
Some of the major errors on the site that were being caused by sections of bad Java Script code have been corrected.  As a result, several of the functions on the site that were previously not working due to Java Script Editor errors now work.  Thank Jim for making this happen in the background without normal site activities being interupted.  Just post here if prior problems are still existant on your end but I’ve found that most (if not all) are fixed on my end.
Sweet!
By Doug T - 16 Years Ago
Cool, now if the "Forums 2006" can be updated to 2009?  w00t
Also for general info, if you edit a post that post's place in the thread order is not changed.  So if you edit a post near the beginning of a long thread it might not be seen to readers actively following the thread in real time.
By PF Arcand - 16 Years Ago
I probably shouldn't admit it, but I'm wondering? Am I the only one on site that hasn't a clue what this post is about?..
By MoonShadow - 16 Years Ago
A lot of the "features" like PM's etc were not working for all of us. I especially like being able to check "recent posts" all in one spot. Chuck in NH
By PWH42 - 16 Years Ago
Paul,Maybe it's something to do with your first name,because I'm in the dark about it also.
By 62galxe - 16 Years Ago
workin much better. had problems changing pages in search,pms etc in the past. now its fixed. thanks
By NewPunkRKR - 16 Years Ago
Not an error, may just a design issue.  After I do a search for something, it gives me back 220 results - I can't just scan through them quickly and move to the next page because it throws "you must wait 15 seconds between each search".  I'm sure the time out is there so people don't rapid fire search and crash the server with pile of threads.  Technically, I'm not doing a different search, I'm just viewing all the results of my current search.  Just makes it difficult look for information somtimes.  Site is great, continue what you guys do - Your wealth of knowledge helps us young guys.
