Looking for a set of STD Main Bearings...
http://forums.y-blocksforever.com/Topic2171.aspx
By Daniel Jessup - 18 Years Ago
My 312 crankshaft has been turned down to the EBU main bearing size. Where can I find main bearings for the 292 in STD without paying an arm and a leg? The "custom" grind on the crank cost me a little more than normal - anybody have successful leads?
Dan
By PF Arcand - 18 Years Ago
Dan: try John Mummert Y-Block in CA at (619) 596-0312, fordperf@earthlink.net (www.ford-y-block.com) or Schumann's Sales in Iowa (563) 381- 2416, Fax (563) 381-2409. These are the two outfits most likely to have what you need. If not try Egge Machine. They specilize in vintage engines. Sorry no contact info handy.
