By JP 1956 - 16 Years Ago
I have a complete original factory 1956/1955 Ford power steering set-up that is 100% rebuilt and 100% complete for all Ford Passenger Model Cars except Thunderbird. I rebuild these unit professionally and take great pain in doing them correctly. You will get everything needed to convert your manual steering car over to power steering and a detail set of instruction from start to finish on how to install the set-up onto your Ford, all you will need to buy is 2 quarts of Ford type "F" or "FA" fluid. All new bolts, new idler arm bushings, new hoses and hose grommet and a new ps belt. All components are painted correctly and all new seal kits installed in ps pump (new filter & bearing), control valve and the slave cylinder come with a new induction hard chrome shaft and poly shaft seal so you will never see a leak or even a drip on your floor, The set-up is fully guaranteed on my workmanship and the unit functionality and performance, if your not happy neither am I! If you have any question or would like to see photo's of the set-up please feel free to contact me Birdoginc@yahoo.com or call Jim 810-334-3522
