By Jim Rowe - 17 Years Ago
Will I need to put the steady rest back on my engine? I have the engine out and in the process of a performance rebuild.
I see no need for the steady rest in my 56 Club Sedan. I will however change from the ford-o-matic to a top loader 4 speed.
Any thoughts?
Jim
By 55Birdman - 17 Years Ago
Put engine in and crank it up.If it idles fine with out the rest then I guess you are good. I was in the same boat and I installed mine because I didnt want to lose them in my collection of y parts.
If it's designed to use them, I would put them in.
By Teros292 - 17 Years Ago
I think that it is not necessarily needed, 57 fords did not have steady rest and the engine mounts are same as 56. At least I am not putting it back.
By oldcarmark - 17 Years Ago
Hello Jim,I believe these were installed to reduce engine vibration at idle and low speed.Apparently many were removed over the years with no ill effect.I put mine back together after I bought the car as the lower metal channel and rubbers were missing.I would think of it as an extra retainer for motor in the event one of the sidemounts let go.Might save you a radiator at some point.
By paul2748 - 17 Years Ago
charliemccraney (1/8/2009) If it's designed to use them, I would put them in.
This is exactly my feeling. When putting the 312 in my 54, I used the steady rest. Can't hurt, may help.
By speedpro56 - 17 Years Ago
the steady rest is useless unless you're in a concours auto show.
By Ted - 17 Years Ago
I‘ll agree with Gary in that you can do away with the front steady rest and never know that it was ever there. I've been both ways on the '55 and '56 cars and it doesn’t appear to make a difference. This particular item goes back to the clean slate engineering that took place when the Y was first introduced and was eventually found that it could be done away with. And It’s definitely easier to install the engine back in its bay when it’s not there.
By dbzach64C - 17 Years Ago
I don't believe I've ever seen a front steady rest on any y block car that's had the engine out. We've been running ours for 20 years now with no hint of a problem.
By crenwelge - 17 Years Ago
All of this discussion makes me feel better. I ran Y-blocks all during the 60's and then I kind of gave up the hobby in favor of tending to business. I never used the steady rests back in the 60's because I figured I didn't need them. I have 3 56 Fords that are original and I am in the process of installing an engine in one of them and had intentions of using the steady rest. The more I think about it, I think I will just forget about the steady rest like I did 40 years ago. I think the side motor mounts will keep the engine from moving around for as long as I will still be driving.
By uncleaud - 17 Years Ago
My 57 T-bird has the side steady rest. Is that what everyone is talking about. My t-bird has a single front mount and a single rear mount on the tail shaft of the trans. Both on the centerline of the drivetrain. If that is the same for the cars it would seem that the steady rods would be needed to keep the drive train from rockin when under a heavy torq load. Maybe I'm readin the question wrong just my two cents.
By DANIEL TINDER - 17 Years Ago
I assumed the steady rests on T-Birds (with front timing cover and rear trans. mounts only, otherwise) were important, as my low mileage original '55 had a serious crack in one of the side-mount plates they attach to.
By bird55 - 17 Years Ago
Yes, we are talking about two different steady rests here. You'll need to keep the ones on a bird, AND the Front mount also. The confusion from this topic for birds comes from the same name "steady rest" but different part-similar to the front mount on your bird.
