Jim - Ted = Posting pictures
http://forums.y-blocksforever.com/Topic20177.aspx
By paul2748 - 17 Years Ago
Two problems - first, I tried to post a picture on the tri power thread - it came back to me saying something to the effect that I had exceed my available space - what is this????
Second, how do you post a picture as part of a response - I see other guys do it but cannot figure how.
Any suggestions. Thanks.
By Ted - 17 Years Ago
Picture posting within the site is quicker and has less problems if pictures are resized so that they are no more than 500 X 500 before posting them to the site.  Automatic picture resizing on this site is limited so it’s best to do it on your own end to speed things up during the posting process.  Most pictures taken directly from a digital camera will also exceed this sites capability to resize them for you.  If pictures are resized on your own end so they are 300 wide (or less) they will download even quicker while also being able to insert them in pairs or two per row (or triplets if at 200 wide) but be sure to hit a hard return after each second picture so a new row can be started.  Otherwise, the pictures just keep going to the right and running off of the screen.  Not using a hard return after inserting the pictures within the thread also makes the text proceed off the right side of the screen thus forcing the reader to scroll the screen to the right in order to read the text.  If wanting the pictures to be in a single row going down, then just put a hard return (enter key) after each picture.
If you’re using another site for hosting the pictures (ie.  Photobucket), then be sure those pictures are sized so they are no than 600 wide at the host site or the pictures will be too large and fall outside the boundaries for normal viewing on this site besides taking an inordinate amount of time to download when pulling up the thread.  If putting text after the pictures, then be sure to use a hard return after picture links to prevent the text itself from scrolling off the right side of the screen.  Likewise, do a hard return after any text before inserting image links; otherwise the pictures will start immediately to the right of the text and potentially go off the right side of the screen depending upon the length of the text.  For those of us on dial up and using conventional monitors, the use of properly placed hard returns makes viewing much quicker and easier.  The upside for using another site for hosting the pictures is that slightly larger pictures can be viewed at the cost of a longer download time when bringing up the post or thread.  The downside is if the pictures are renamed, moved, or deleted from the host site, then they are also no longer viewable on this site.
Here are a couple of past threads with additional instructions on picture posting.  Other posts regarding picture insertion can be found by using the search function.
http://www.y-blocksforever.com/forums/Topic6165-6-1.aspx
http://www.y-blocksforever.com/forums/Topic7693-6-1.aspx
Feel free to practice picture posting within this particular post.  If necessary, I can re-print the text from one of the linked posts above into this post that goes into more detail on the step by step specifics of picture posting.
Nothing works. I got the photo from Photo bucket, copied the IMG thing then did a post reply thing. Clicked on the mountain, the box that came up (said Enter the full url to the image to insert) would not let me enter anything.??????????
Please - I'm not dense when it come to directions, but nothing works.
Still - why does it say something to the effect I've used up my space when trying to insert a picture.
How about some good directions? The two threads mentioned do not work for me.
By Ted - 16 Years Ago
Picture test.
paul2748 (12/31/2008)
Picture posting instructions when not using an outside picture hosting site (ie. Photobucket):
1. While in the editing mode, select the icon with the mountain and sun in it.
2. Select “Browse” in the popup window
3. Go to the directory where you keep your pictures.
4. Select your picture.  Downsized works best.  Too large may be too big period.
5. Select “Open”
6. Select “Add Image”.   Do not use the link bar in this instance.
7. Wait….  This could take a couple of minutes as your picture (if not inordinately large) is being downsized and uploaded to the site from your computer.
8. Then popup window goes away and the picture starts to display within the editing window.
9. When the picture is fully displayed, hit the enter key (hard return) and add more text if desired under the picture.
10. Select “Post Reply” and the updated thread should then display with your picture in it.
By paul2748 - 16 Years Ago
Ted - thanks for the directions, but
#2 does not work
If I click on the mountain/sun icon, what comes up is a rectangle. Inside it says "Enter the full URL to the Image to insert". No "Browse" shows up to click to click on. So after #1, I'm out and nothing will work?????? I have used the browse command in a number if sites I look at, including ebay and that always works for me. I just don't understand why this does not come up when I click on the mountain/sun icon.
I am using Mozilla Firefox if that makes any difference.
I am going to try this on aol to see if it makes any difference
Nope - aol does not work either In fact, the rectangle does not even come up on aol.
By Unibodyguy - 16 Years Ago
     Well going to give this a try and see if I can make it work.
                                        Michael
Well I guess I did something right I got a picture up!!
                                          Michael
paul2748 (1/1/2009)
Ted - thanks for the directions, but #2 does not work....
Paul.  Your settings on the site are the same as the other members which points to the problem being back at your own computer and possibly your browser settings.  On a slightly different note, do you perform any routine maintenance such as keeping the recycle bin empty, disk or drive cleanup, cookie cleanup, and performing a Defrag?  Not doing any or all of these will have your computer slowed down to the point that there’s not enough RAM remaining which can potentially keep extras like ‘Browse’ buttons from coming up in a speedy manner.
But assuming all is well from a memory standpoint and you have no Grandkids around that can get the browser settings to function as desired, then using an outside picture hosting site such as Photobucket is another option.  Here’s some instructions for this.
1. In Photobucket, select the IMG CODE under the desired picture and copy into your memory buffer (Cntrl + C).  The IMG CODE should be the last one in a list of four under the picture you’d like to use.
2. Be sure the picture is downsized before storing the link into the buffer.
3. Open up the YBF post editor to the post for which you are going to add the link.  (Add Reply, Add Topic, Edit)
4. After adding any desired text, hit a hard return (enter key).
5. Paste the desired link into the edit screen (Cntrl + V).  Only the link will show at this point and not the picture.  Make sure the IMG brackets are fully intact after pasting in the link.
6. Add a space using the space bar behind the link.
7. Put a hard return (enter key) behind the space.
8. Add text if desired.
9. Select the ‘Post Reply’ key.
10. Updated post should then display with the picture also displaying.
By 55Birdman - 16 Years Ago
Paul the browse button shows up next to the window where you are to enter the URL address. I had many issues when I first started like you're having. Then one day it started working. If you dont have the browse button then I am lost.
Jim, Ted:
I noticed this morning that the picture of the car included in my post on the Street thread, concerning leaf springs, has changed.  It is no longer my car.  Did I do something to cause that?  It is a good looking car though.
John
Did it again here too.
John
By aussiebill - 16 Years Ago
John, i think one of them yblockers have kidnapped your car  to check out your engine to see whats in it! Dam y blockers?
I realized it is Dutchy's car that shows up on my posts.  Some kind of foreigner plot????  I just saw my car an hour ago, but didn't raise the hood.   Maybe I should.
John
Aussie Bill That is one beautiful car!!  I have it on my computer as my screen saver.
Here goes nothing
success maybe??
Ted thanks, I got the photo thing going through my photo bucket account.
You mentioned that I may have some browser settings problems. Do you or Jim know what should be done or what i can check?
Jim, Ted:
I see my car came back.  What happened?
John
Hoosier Hurricane (1/4/2009)
Jim, Ted:
John
John.  Afraid I accidentally did that .  And I don’t even know how it happened as I was working on getting some of the other signature pictures reduced and didn’t think I was anywhere near yours.  Anyhow, I got with Jim and he was able to restore your original signature picture back to your profile as it was a link to a YBF picture file that I couldn’t get back to.  Sorry about that.
By ejstith - 16 Years Ago
I think this picture insert is a pain too. I have never been able to post a picture on here. Where is says "Insert Image" there is a URL thingy. It should be to where there is a way to get one off of one's PC picture file and just upload it. (See the HAMB website). Much simpler. I don't even have any success changing fonts, colors etc with this. If I hit the font color thing it just asks for some color code. If I hit "bold" it puts the [B] in the front and back of the text then a message comes up saying there is basically nothing between the [B]'s. I'm not a webmaster by any means but this should not be this hard to do.
ejstith (1/4/2009)
This is the same problem that I have. Apparently its not my computer but a glitch in the software????. This reminds me a problem with pictures and replies back a number of years ago (I couldn't do either). Turns out it was some glitch in the software, a few adjustments by Jim???? and everything was ok. I have no problems uploading pictures in HAMB, ebay and some others which have the "Browse" function as a way of loading pics right off my computer, as well as various software I have on my own computer which also uses the same "browse" function.
Guys.  This is as good as it gets for the time being.  Being a no cost site, there’s simply no finances to get outside resources to look at the known issues.  Granted that the Java Script editor not being right (a known problem) could potentially be part of the problem, I don’t have access to the code and therefore I’m clueless on how to get that part fixed as Java Script editor issues in themselves inhibits certain functions on the site for myself.  I’m just about as computer illiterate as the rest of you but given enough time with some code sitting in front of me in written form, I can usually figure it out.  Especially if I have a Rosetta stone sitting next to whatever I'm working on.  But the ‘insert image’ thing does work for myself and others so this is not an across the board issue.  Unfortunately there are just too many different operating systems out there with their own specifics for browser settings which makes it difficult to troubleshoot problems that do not show up across the board.  Through trial and error, I’ve readjusted my own browser settings to optimize my own computers performance and this doesn’t by any means make me any kind of webmaster.  Just remember to take notes when readjusting any settings so you can put them back where they were if need be.
The alternative option for picture posting is to simply use an outside photo hosting account such as Photobucket and go that route.
Ted:
Here we go again.  This free website.  Yeah, it's wonderful, and Jim doesn't know how much he's appreciated.  But, if it takes a little money to hire someone to evaluate this picture issue, then let us each kick in a few bucks and "git 'er done".  We've been freeloading for years now, and Jim won't let us help, maybe we can help in this way.   I don't know anything about pictures on computers, but I'll still help.  Any idea how much money would be needed?  If a handful of Y guys can raise $4000 for our shootout, without hurting anyone financially, then the bigger base of participants on this site should have no problem with raising the funds.  Count me in for something.
John
Hoosier Hurricane (1/5/2009)
Ted:
John
Me too ... I give 50 bucks a year to be an Alliance member of the HAMB and I'd do the same here to be a Yblock member.
57 Ford Kustom (1/5/2009)
Like John here we go again. Let us pass the hubcap around to help fix the problem. I have said it before, tell me how much and where to send it.
TCoolM
I have no problem with that
By mctim64 - 16 Years Ago
Tell me where to send it and I'll kick in. BigGrin
By Eddie Paskey - 16 Years Ago
Count me in!!   Where do we send the money.   THANKS JIM---  and all that help this site be what it is!
      God Bless   Eddie
By sundance241 - 16 Years Ago
count me in.........................By the way , i have a question ,...how come there are no profiles from Florida ?  is this still being worked on ?  i find it hard to believe nobody from Florida  has sent a profile..!!  I did...!!............................Sam.............West central  Florida
sundance241 (1/6/2009)
Check it now.  Jim let me know that the Florida profiles are now in place.
Ted ,   I am going by the prifile map ,   maybe i am doing something wrong ,  but when i go to the map , it says,  click on the profile marker ,   the nearest marker to Florida is  alabama ,   and shows nothing  in florida !!         Please let me know if i am notuseing correctly !!.......................Thanks for your reply.........Sam                           Florida
By Teros292 - 16 Years Ago
You have to click update button on your webbrowser or then you have to empty your browsers memory cache to update the website. I looked and there is Florida on profiles.
I see profiles in Florida but none in Georgia.
Tero ,  I dont see any  up-date button .!!...............  Charlie  ,  I dont see any profilies  for Ga.    or Fla...............Sam
Looks like it depends on what browser you have, on windows explorer looks that "F5" button update the page and on Firefox "Ctrl + R" does the job also.
sundance241 (1/8/2009)
I dont see any  up-date button .!!......Sam
Try refreshing the screen.  In the browser bar at the top of my own screen, it’s the little white page icon with two circular green arrows within it.  Placing the cursor over the icon has it saying ‘Refresh’.  Assuming your screen does refresh, then enlarge the map by a couple of + clicks so that the U.S. is larger or more detailed.  At that point, Florida does come up on my screen and then clicking on the Florida marker shows that there are six entries.  But I don’t see a ‘Sam’ as one of the entries so you may need to resend your profile to Jim again.
Cleaning up or deleting the older cookies in the Temporary Internet Files folder may also help as far as refreshing the screen goes.
Ted,   I did what you said ,   but after enlarging the page or map ,  when i press the refresh button ,  it just goes back to the original size page......all this with no markers in Flo. and Ga.......But i reckon jim didnt recieve the info  and pictures from me anyway .............Sooooooooo  i reckon i need to get some one  that knows more about my computor than i do , to check it out................Thanks for your help................Sam.......................West  Central   Florida
By Richard Miller - 16 Years Ago
I never follow instructions, lets see if this will work
another one
last one
