FOR SALE 292 SHORT BLOCK & Y-BLOCK PARTS
http://forums.y-blocksforever.com/Topic18291.aspx
By 1957ford.com - 17 Years Ago
FORD Y-BLOCK SHORT BLOCK 299 INCHES
$1900.00
FOR SALE - 1955 to 1964 Ford Y-Block Complete 292 CID Short Block Assembly. Rolling Assembly. Just completed and done right.  Started as 1957 Ford 292 Y-Block.  Block Cylinders Sonic tested, Deluxe Degrease, Align hone main caps,  Align hone for cam brg. 90 degree Deck Mill to Square block true 90 degrees. Bored cylinders .050
= 299 CID.  Performance Power Hone. New 312 Cast OEM Style Pistons with Chrome Moly Rings and New Bushings and Pins. Added 1961 Crank Shaft, turned .020, reconditioned, polished and balanced. 1961 C1TZ Rods, crank turned .020, reconditioned, shot peen.  ISKY 3 Camshaft, Hand degreed in, New Lifters, New True Double Roller Timing gears and Chain, Brass freeze plugs, New small parts kit, Neoprene Rear Main Seal.  Also includes New Gasket Set. Used: Timing Cover, Oil Pan, Pick-up Tube, Oil Filter Adapter, Harmonic Balancer. Engine Short Block Assy Sold as is, Where is, No Warranty, or returns.  Have paper work and all information. If companies want to warranty that is between you and them.  There is no shipping from my end, unless buyer sets up. This will make a excellent complete and long lasting engine. Plenty of low and mid range power and of course that good old Y-Block Top End......... Please contact me for more information.
By sundance241 - 17 Years Ago
Where are you located ...?..........Sam
By 55Birdman - 17 Years Ago
do you have a thermostat housing? need one for 292 tbird
By mctim64 - 17 Years Ago
Kenbob (11/10/2008)
I need to know where your located?
click on the "Go Up" that wil tell all. BigGrin
I need that therm housing. e-mail me eadgpdhome@msn.com
I am located twenty five miles north of Cincinnati, Ohio. Email: gambill@1957ford.com
Have other misc. parts to go along with engine and engine parts listed above. Package deal for all engine stuff  $4000.
John E Gambill Sr
Lebanon, Ohio 45036
