By ltman - 17 Years Ago
Ok guy my freind has got over 400 cars most of them are in the 50s lot of comeplet motors bad news all ford y blocks have ben rained in but may be 1 Trying to find out about these parts i found this sit There is 1 motor i thinks a ford but im not for sure The intake reads EDG-8425-A I like all old cars I like to see some of these parts get salvaged
By Tom Compton - 17 Years Ago
What is the general location? CA? VA? KA?
WV There is over 100 ford and mercurys I no i have 4-5 standard trans for the y block still in car all linkage atached I have lots of tools and torch if needed
Do you have trucks as well?
yes but most of the truck parts are all gone
Yes i have the hole set up I also have the hole motor set up if any 1 needs it Pump, pullys, and brackits I also have 59 front grill RH-7-59 and Lots of glass
By John F - 17 Years Ago
If your still looking for power steering parts, take a look at these they may be what you need. http://cgi.ebay.com/ebaymotors/ford-1957-1958-1959-power-steering_W0QQcmdZViewItemQQcategoryZ42606QQihZ019QQitemZ290268230292QQrdZ1QQsspagenameZWDVW
By CodyConley - 17 Years Ago
How much for one of those bell housings off the manual Merc anad are you willing to ship to NY. Also looking for a couple Carter 4bbl carbs WCFB #2361 of a 56' Merc. Thanks.
40 plus shiping for bellhousing I dont have any ford 4 barrals I have some COAE heads for Y block if any 1 inrested Hears a listing of some mercury manifolds i have http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150308009177&sspagename=STRK%3AMESELX%3AIT&viewitem=
I got these mercury manifolds on ebay Mercury manifolds
By timmy4 - 17 Years Ago
Do you have any dor panels for a 1955 customline?
By PF Arcand - 17 Years Ago
JBO: Good luck trying to find cheap good Rams Horns. If cheap are probably rusted, cracked or have broken ears. Best wait till you can afford decent or new ones. Mummert's are $375 including gaskets last I heard. Also be careful, some mistake Lincoln/truck ones for Ford/Merc Y-Blk. They don't fit.
