Water pump pulley
http://forums.y-blocksforever.com/Topic17405.aspx
By dbzach64C - 17 Years Ago
Any of you fellows have, or know of one for sale, a water pump pulley like the one pictured here? At least I hope the picture made it. This one is on a friends 312 in a 39 Ford street rod and it originally came off of a "59" 292 he thinks. I believe the part number is B5A 8509-F. 6.30" OD, 2.40" depth, 1/2" sheave width. Thanks
By 55Birdman - 17 Years Ago
I am going to pick up an engine tomorrow. I dont remember  it it has a pully on it . If it does I'll send it to you . I dont need one so you can have it just pay shipping. . I will let you know tomorrow late.
A 57 and 58 truck has turned up at a local pull-a-part yard.  I'm going to check them out.  Probably won't be until next weekend.  If one is there I can pull it.
Thanks for the assistance, much appreciated.
By Glen Henderson - 17 Years Ago
Charlie, I tried to PM you, but for some reason I can't get it too go through. Take your camera when you go to pull-a-part and if the truck has any decent sheet metal let me know. In regard to the pulley, I have several truck pulleys, but I have never seen one that looks like yours, unless it is two pulleys stacked together. If it is just the single grove inner pulley that you need, I just pulled one this morning.
After looking at the picture again, I have never seen one like this, I don't think its from a Y Block unless it came from an aftermarket A/C kit.
No pulley on engine sorry
By oldcarmark - 17 Years Ago
Hello Newbie,
I just had a look at my parts book.That particular pulley was used on 55 -57 Y-block for A/C.Its the only one listed with that 2.40 depth.There a couple of others similar but they are 2.46 depth which I guess sits back a little further.This is a single pulley stacked on top of the stock one.Thats going to be a hard one to find.Good luck.Regards,Mark
Will do, Glen. Is there any part in particular that you need. You can see prices at www.pull-a-part.com. As long as I have enough cash in the bank and room to bring it back, I'll get what you need.
Thanks Charlie, a buddy of mine has a 58 and he is always looking for "stuff", just though that I would pass info along to him if it looks like it would be worth a trip to "Hotlanta". We have a local Pull-A-Part and you can find some good deals there if you check them everyday or so.
By Carson - 17 Years Ago
here is the Y block pully gold mine
Phill Mott
tel 928-425-3486
HC02  Box 491
Globe, AZ 85501
Haven't made it down to the salvage yard yet, Glen. I'm trying to make the last test and tune of the season next week. With it getting cold I haven't had much usable time to work on things.
If you are still looking for this,check Ebay item#250322981834.It looks like the one you are after.Regards,Mark
