If Timing Gears were not installed as they should be. Will it still Run?
http://forums.y-blocksforever.com/Topic171198.aspx
By oldcarmark - 2 days ago
Trying to get an answer for a Question posted elsewhere, If the Timing Gears were installed as most conventional V-8's are instead of facing to the side would it still run although not well?  There's a Post on the Facebook y-Block site asking for help. Rebuilt Engine with new Balancer.. TDC on Engine with Valves closed lines up with TDC on Balancer. When Engine Starts Timing is well advanced. Turning Distributor back to 10 Engine runs terrible. Says wiring is right. I think His Distributor is out by a couple of Teeth. Opinions?
By Ted - Yesterday
If the timing chain for the Ford Y is installed at 11 or 13 pins between the marks, the engine will start and run.  Beyond that, it is questionable.  I have seen an instance where the chain was installed with the timing marks aligned vertically instead of using the pin count and, in that situation, the engine turned over like it had no compression and would not start.
The only time the distributor would need to be clocked differently on an assembled engine would be if the distributor cannot be rotated enough to get the ignition timing correct. If relocating the cam timing by moving the gears, then the distributor would likely need to be moved a tooth or two at the distributor gear.  The fact that the engine does start and run up does point to the camshaft timing being a tooth or two off at the timing chain.
If you would like to verify the cam timing without disassembling the engine, one way would be to slowly turn over the engine and watch the valves on the #1 and #6 cylinders.  When either cylinder has the exhaust valve closing, watch for the intake valve next to it to just start opening.  Using a short straight edge (popsicle stick works for this) on the retainers and when both valve retainers are level with each other, then stop the rotation.  At this point the exhaust valve is not quite closed and the intake valve has just started opening.  You can verify that by just checking the rockers and ensure that there is no lash present.  It’s important that the crankshaft is always turned in a CW rotation as looking from the front of the engine and not in a CCW rotation.  Chain slack can alter the cam positioning making it necessary that the engine be always be turned in the direction it normally rotates while doing this.
Now look at the damper.  In the grand scheme of things, a perfect reading at the damper would be in the 4-6° advanced (BTDC) range.  If you see a distance from TDC that correlates to 20° or more on either side of TDC, then odds are good that the timing gears were installed in the wrong position.  This is assuming the timing marks on the damper are indeed correct.  By the book, the TDC on the damper is required to be located 108° clockwise from the keyway slot for the timing marks to be correct with the pointer.  It’s also important that the timing marks on the damper are positioned correctly in relation to rotation.  I have seen dampers that had the damper ring installed backwards making the timing marks read ATDC rather than BTDC although the 0 or TDC was correct.  That will throw you a curve if not looking for it.
Another option is to simply run a compression test on the engine with the throttle blocked in a wide-open position.  Abnormally low readings would point to the cam timing being incorrect.
I for one would like to hear the outcome for this when it becomes available.  Other comments always welcome.
