Stuck pistons
http://forums.y-blocksforever.com/Topic170928.aspx
By cos - Last Month
Hello Members    trying to save a C2 block.. Pistons are stuck in bore (rust) just started working on getting them out. Crank of course will not turn so no getting to all rod bolts  to pull crank.. Have bores soaking in penetrating  oil. Heat, bigger hammer any thoughts?
By KULTULZ - Last Month
Was the engine (short or complete?) left out in the weather? Spark plugs or intake removed when you found it?
By cos - Last Month
Complete  No carb must have gotten water thru intake manifold.  or exhaust manifold.
Maybe fill the cylinders with solvent. Put plugs back in. Allow the engine to sit for a week. Remove plugs and gently try to turn.
If it breaks, continue to turn slowly and gently (as the bearings will also be dry). Maybe blow out solvent and squirt oil around  the ring lands as possible.
Are you trying to save the lower end or go through it?
By cos - Last Month
Stripped to block, crank,rods and piston.  Basically trying to save block. Crank looks good and has HD rods. Did have a iron georotor oil pump.
Is the engine on a stand with heads removed?
Maybe install the heads with old gaskets to be able to hold solvent for a week.
Sometimes, a sharp blow with a dead-weight hammer or block of wood on the piston will break the hold.
Otherwise the piston will have to be hammered out from underneath.
SHOCK AND AWE always  bothered me.
Hopefully Ted will see this and give better advice.
By paul2748 - Last Month
Break up the pistons from the top if you do not want to save them.
By cos - Last Month
Thanks Paul  not the trying to save rods or pistons. Engine should have had the beefer rods. Got one out it it is  EDB, not worth trying to save Hoping Kroil oil and heat will work.
By cos - Last Month
Hello  Pistons are out.  Kroil oil, 3 pound hammer and torch.  Thanks
By 55blacktie - Last Month
cos (10/16/2026)
Any damage to cylinders?
By cos - Last Month
Doesn't look like  it.   Friend had it and was junking 4 or 5 Y blocks. Not planning on using it but c2 are hardest one to find, save 312s.
