Neoprene Seal Lip Faces which Way?
http://forums.y-blocksforever.com/Topic170343.aspx
By oldcarmark - Last Month
Putting My Engine back together. Using Best Gasket Set. the Neoprene Seal has a Lip. Which way does it face. Front of Engine or back? Getting Old. Can't remember. thanks!
By Hoosier Hurricane - Last Month
The lip faces the fluid you are sealing.  The rear main seal lip faces the front of the engine, the  front crankshaft seal lip faces the rear of the engine.
Thanks John. I kinda thought that was the way but better to ask than guess.
By DryLakesRacer - Last Month
If you ever go crazy some day building a racing engine with a vacuum pump remember to turn them around. Cost me a few inches on the crankcase vacuum gauge in the first engine I built using an Aerospace Components Pump.
