By oldcarmark - 6 Months Ago
I watched One of John Mummerts U-Tube Videos regarding installing Oil Pan. He uses Permatex Grey as a Sealant on both sides of Pan Gasket. On the Block and Oil Pan. Is there a reason for using the Grey instead of Black? I also watched His Video on installing Rear Main Seal. He mentions that He believes the majority of Rear Seal Leaks are NOT the Seal itself but the Side Seals. He showed how He coats Side Seals with Silicone to hold in place on the retainer and then installs the retainer. My Question is why are the Side seals still being used when the Space where the Side Seals go could simply be filled with Permatex "Right Stuff". I can tell You from experience that doing it with "Right Stuff" will not Leak. I did mine a few Years ago and had no Leak. when I took it apart to rebuild it I had to cut the sealant with sharpened thin Putty knife to get the Retainer out. It would flex but not separate with the Bolts out. The Side Seal Space will not allow Oil to Leak if filled with Sealant. He mentioned in the Video that in the rare Occasion that Rear Main Seal does Leak when installed His way He simply redoes the Rear Main Seal. I like my way much better than even His way of doing it. Thoughts?
By FORD DEARBORN - 6 Months Ago
I agree the rear min seal itself often takes the blame for side seal leaks. There is constantly new advancements in sealer technology and "the right stuff" may be the best substitute for solving the side seal issues. I have had experience with a fairly new caulk that has excellent adhesive characteristics and holds up when filling large gaps even when flexed and can be applied to somewhat wet surfaces. It is supplied in a clear tube for caulk applicators but I can't remember what it's called. So why not develop the product for the automotive world as well? At this time, should I rebuild another y-block, I would try it. Why not buy a tube and experiment?
Well I am in the process of re-building mine. Using "Best" Gasket Set which includes rear Main Seal. I will be using "The Right Stuff" again. I like the Odds much better using the Sealant rather than Side Seals. The Rear Main Seals was a problem right from the Time these Cars were new. Not a great design along with the Original Tin Valley Cover. I have a New Mummert cast Cover to go on mine. Another potential leak fixed.
By KULTULZ - 6 Months Ago
By Ted - 6 Months Ago
I use the Ultra Black RTV as it tends to be more pliable when it dries than the ‘Grey’ series. The Black does require longer drying times and overnight works for this. If time is of the essence, then the grey dries much more quickly.
Question answered. Thank You. I am in no hurry to put back in service so Black it is. Also going to use in place of side Seals.
Going to use the Black RTV on Gaskets and the Black "Right Stuff" on the Rear main in place of Side Seals.
By 55blacktie - 6 Months Ago
Let us know how it works out.
When I inherited my 55 Tbird, anything that held oil or ATF leaked. I hope to do better.
By RossL - 6 Months Ago
I just completed the rear main seal in 55 292. I bought a kit from Prestige Thunderbird. They supply a new aluminum block the two neoprene seals and a tube of Permatex Grey. The Permatex is used in place of the OEM rubber/metal staked seals. It worked very well. My biggest challenge was getting the rope seal out. Send me your email if you want to see a copy of the instructions
By paul2748 - 6 Months Ago
I use the orange RTV in where needed (pan, front cover, thermostat housing, etc) and it has always worked out very well. The engines I had rebuilt (short blocks) were done by outsiders and have no idea what they used/did but, knock on wood, I don't have any rear main problems. The information about Right Stuff is interesting.
paul2748 (4/18/2026)
I use the orange RTV in where needed (pan, front cover, thermostat housing, etc) and it has always worked out very well. The engines I had rebuilt (short blocks) were done by outsiders and have no idea what they used/did but, knock on wood, I don't have any rear main problems. The information about Right Stuff is interesting. I've used the same for the water pump, Tbird spacer, and thermostat housing.
