Rear Main Seal Inspect
http://forums.y-blocksforever.com/Topic169764.aspx
By Richard - 8 Months Ago
Looking at the crank to flywheel section.  I see no oil dripping. So oil leak is not there. After reading Ted’s statement I did not use studs in.
I think the studs should have the middle unthreaded. Is that correct? But where can I easily find them. Each end is 5/16 18 total length 1’’ TO 1 1/4 OR 1 to 3/8’’
Found em on amazon
By 55blacktie - 8 Months Ago
The studs are 5/16-18 on the retainer cap and 5/16-24 at the oil pan. Ted said that the overall length of the original studs is 7/8ths; however, the shortest studs I could find have an OAL of 1 1/4.
Got 3/4 on Amazon
I just went to Amazon's site and searched 5/16-18 x 3/4 and found nothing that size. Is 3/4ths long enough?
OPPs it was 9l16 lower and 7/8 upper in length
they also have 3/4
my search was 5/16 double ended stud
Blackie,
I had ordered an assortment of  studs. 7/8 1 1/4  1 1/2. I can return the ones I don’t use.
1 1/4 IS THE ONE. Installed with thread sealer looks just right.
My plan, since working under the car, I’m putting two more studs in the front to hold the silicon gasket in place.
Blackie,
Thanks, Richard. I had already ordered Dorman 23733 Water Pump Stud Kit from Walmart. The retainer cap end is 5/16-18 x 7/16 and the pan end is 5/16-24 x 5/8. OAL is 1 1/4. It hasn't arrived yet, but I guess it will do.
FYI: The specifications listed by Dorman for the 23733 stud kit is incorrect. One end is 5/16-18 and the other 5/16-24 (as they should be); however, Dorman says that the 5/16-18 end is 7/16 while the 5/16-24 end is 5/8; this is backwards. The 5/16-18 end is 5/8 while the pan end is 7/16. The specified OAL of 1 1/4 is correct, but the included nuts are 5/16-18; they should be 5/16-24.One other thing: Dorman's photo displays zinc-plated studs, but they are black oxide.
I've sent an email to Dorman's Customer Service and pointed out the error. Unfortunately, retailers are using Dorman's specifications.
According to Tim Hill, the oil-pan-to-retainer stud part number is 88351-S8; however, it could not be found on Hill's Thunderbird site. I then did a web search of the part number and found it on NPD's site. The studs cost $2.06 each, but shipping will exceed the cost of the studs. Nuts & washers are not included.
By KULTULZ - 8 Months Ago
http://forums.y-blocksforever.com/uploads/images/0b349e8d-eb38-44b1-bcb7-b001.png
88351-S8 is the correct part number for the studs. Tim Hill said that they weren't included in their catalog/website due to low demand, but both will be updated. NPD has them, same part number.
By 55blacktie - 7 Months Ago
55blacktie (2/17/2026)
The 88351-S8 studs arrived yesterday, but they don't fit. Although the OAL of 7/8 is correct, I think the zinc plating is preventing them from being screwed into the retainer. I double checked them by attempting to put a 5/16-18 nut on, but wouldn't work. The Dorman studs that I had previously bought fit the retainer, but they are 3/8 longer at 1   1/4. I will use the Dorman studs and hope that the extra length won't be a problem.
I sent an email to Hill's, requested a refund, and told them to check their stock before fulfilling any more orders for the studs.
Here is a quote from Hill's: "We went and talked with the lead mechanic/tech on the restoration side. He told us that the side that goes into the cap will not finger tighten, you have to use a tool to tighten them into the cap. I believe [they] have prevailing type threads so they cannot rattle back out. I tried a 5/16-18 nut and it was the same as the cap." Of course, I'm concerned about trying to install a steel stud into an aluminum retainer cap. I've experienced enough stripped threads for one lifetime.
By oldcarmark - 7 Months Ago
Am I missing Something about these Studs?  I took mine apart and there are Bolts holding Pan to Seal Retainer.  What is the Purpose of having Studs instead of regular Pan Bolts?
Ted confirmed that the 5/16-18 end of the 88351-S8 stud has "prevailing threads." To install it in the cap, it has to be double-nutted; it can't be screwed in with your fingers. I had never heard of "prevailing threads." Ted continued to say when the 88351-S8 stud is not available, he has used a Moroso stud with an OAL of 1 3/8; the extra length, apparently, isn't a problem. With either stud, he recommends using Loctite Blue or equivalent on the cap end to prevent an oil leak.
Same Question  I asked in My Post. Why are Studs used in this situation. Took mine apart. No Studs just regular Pan Bolts.
By FORD DEARBORN - 7 Months Ago
I believe it's best to use studs as opposed to hex head bolts in that application. The seal retainer is aluminum, much softer than cast iron and those threaded holes enter the interior of the engine where lots of oil is thrown around. Therefore the studs must be installed with a very good thread sealer when all is clean and never disturbed after being screwed in. Simply remove/replace the nuts when dealing with the oil pan. That would avoid leaks and possibly stripping or wearing out the threads in soft aluminum either from over torquing as an attempt to stop it from leaking or from repeated use. Just my 2 cents worth....
OK Thanks. Makes sense but I don't think the Bolts in mine were leaking. I may try and locate some Studs.
By Ted - 7 Months Ago
Mark.  If you are not leaking any oil, then it would be advisable to just leave the two bolts in place.  Sealer on the bolts when they are installed in the rear seal retainer can prevent the aforementioned oil leaks in that area.  From the factory, there were two studs installed in the rear main seal retainer to eliminate the possibility of any oil seeping past the threads.
I get a large number of core engines missing those studs which is the first indication that the engine has been into after leaving the factory.  The Mr Gasket #59 stud kit is what I use when I do not have the actual original Ford studs to use.  Because these studs do not have an ‘interference’ type of thread, some Loctite is required which also helps to seal the threads.  While they are longer than the original studs, the extra length is not a problem.
Studs when properly installed along with some type of sealer will prevent oil from seeping past the threads in the rear main seal retainer.  Using bolts rather than studs in the rear main seal retainer does increase the risk of an oil leak in that area and expecially if no sealer is being used.  Any oil making its way past those particular threads will look like a rear main seal leak and that could end up being a considerable amount of work being performed that is not actually addressing the root cause of the oil leak.
88351-S8 studs are Loctited in, but I felt like I was rollin' the dice.
