Rocker arm rebuilding
http://forums.y-blocksforever.com/Topic169465.aspx
By cokefirst - Last Year
35 years ago I owned an auto parts store.  At the time there were companies that rebuilt the rocker arms on these engines.  Is that still done?  Is it cost prohibitive?  I have some used rocker arms that the shafts are galled from likely lack of maintenance.  I would like to have them rebuilt and keep in stock as I own six 1955-1957 Y block vehicles.
By 55blacktie - Last Year
Rocker Arms Unlimited in Redding, CA can rebuild them. You can buy new shafts from several sources. John Mummert (ford-y-block.com) sells components and complete assemblies. Tim McMaster (yblockguy.com) has a video on rebuilding rocker assemblies that includes "pressurizing" them.
thank you!  I will look at Tim's video.  I use him for my engines.  He is great!
He wasn't/isn't interested in building mine, possibly because I've already acquired most of the replacement parts (all quality including parts he has used on other builds).
By RossL - Last Year
55blacktie (12/10/2025)
What parts did you buy?   I've seen the shafts, what else is needed?
Mummert (SI) stock-size stainless valves
Mummert Stroker H-Beam rods
Clevite bi-metal Buick rod bearings (also from Mummert)
Racetec (Autotec) 3.825 flat-top forged pistons
Sealed Power ,010 main bearings
Hastings metric rings (1.5, 1.5, 3.0 mm)
PAC 1286 beehive valve springs, retainers, & 10-degree locks
Holley 1850 Street Avenger 570 carburetor
CRT tach-drive distributor
Sanderson Tbird ceramic-coated headers
Casco water pump
Powermaster PowerGen alternator
Carter M6905 fuel pump
Howard's Cams 292002-10 cam
Verne Schumann's Durabond cam bearings with center bearing grooved on back side
ECZ-G (non-posted) heads were ported by me, decked .013, hardened exhaust seats & bronze valve-guide liners installed, 3-angle valve job (30, 45, 60/w intake valves back-cut 30 degrees), guides cut for ,500-lift cam & Comp Cams Viton positive seals
ECZ-B intake ported by Ted Eaton
Dampener rebuilt by Damper Dudes
Rollmaster timing chain set
1.60-ratio rocker assemblies purchased from "Richard" on this forum (probably sourced from Rocker Arms Unlimited, not aluminum Harland Sharp)
In other words, there's not much left to be purchased.
