Overdrive cable
http://forums.y-blocksforever.com/Topic169107.aspx
By montana ford man - Last Year
I’m trying to put my cable on the overdrive in my 55 crown Victoria. Is there a special bolt that attaches the cable to the transmission? It seems if I put the cable between two washers on a nut and bolt,it binds up.im thinking it’s not right. I guess im missing something.  The car didn’t come with an engine or transmission so I never had the original parts any help would be greatly appreciated
By FORD DEARBORN - Last Year
That bolt that secures the cable must be able to rotate freely in the overdrive lever attached to the trans. The bolt usually has a hole cross drilled close to the bolt head to accept the cable. The heart of the assembly is a flanged bushing that allows it to rotate yet tightly secures the cable that is sandwiched between two washers. I'll try to post a couple of pictures of one I have on the shelf. Washers of various thickness can be selected to minimize any excess play. Hope this helps....
http://forums.y-blocksforever.com/uploads/images/cb5b2150-2865-44d0-9555-6aa1.jpghttp://forums.y-blocksforever.com/uploads/images/42037d78-7506-4524-83d7-a26d.jpg
Thanks for the good information. I thought that it had to be something other than just a nut and bolt. I think I may have that bolt but if I have it I will have to dump boxes and coffee cans to find it! Maybe I can order one or maybe make one.  Thanks again for the picture I appreciate it.
