Fuel Line route from tank
http://forums.y-blocksforever.com/Topic168779.aspx
By Richard - Last Year
My 54 Ford Fuel line  from the tank routing is now going up the frame curve  over the axel, then down the curve and along the frame.
That means fuel has to travel up the frame from the tank first. My factory book isn’t clear.
Although it doesn’t seem right,  what is the correct route.  I certainly don’t want it to hit the axel.
Any pictures appreciated
Thank You,
‘Richard
By MoonShadow - Last Year
Following the frame above the axle is correct. Its an easy curve and the fuel pump will still draw the fuel through.
