Oil cooler?
http://forums.y-blocksforever.com/Topic168204.aspx
By 58F600 - Last Year
Hey all. The old 58 F600 Turbo is still going strong. Ran it all winter and hauled probably 100 loads of dirt through the hills in Tennessee. Heating issues were fixed! Now that it's warming up, the temp is creeping pulling long hills loaded. But staying under 195°.
I was thinking of adding an oil cooler just to help it stay cool during the warmer months and long hard pulls.
Anyone done this? Any thing special for adding an oil cooler to a y block? I know most universal ones just add a sandwich plate to the oil filter.
By Joe-JDC - Last Year
If your water temperature is staying under 195* then you do not need an oil cooler.  Temperature in the oil is actually good for the engine depending on the type of oil you are using.  A good 10W-30/40, or even 20W-50 when it is warm works well.  Keeping the water temperature in control will keep the oil temperature in control.  JMO, but it works for me.  Joe-JDC
By Ted - Last Year
Joe is absolutely right in that the oil being hot is better than cold.  If monitoring the oil temperature itself, then 250°-260°F would be my limit but unless the engine itself is running abnormally hot, the temperature of the oil will be fine.  In the event the oil is indeed approaching an upper limit oil temperature, then adding extra oil capacity would be a quicker short-term fix.  The HD truck engines used an oil pan that was 1 quart larger but making the existing oil pan larger would be another solution.
Be forewarned that if going the remote oil filter or remote engine oil cooler route, then it’s important that the size of the lines is adequate.  Under no circumstances should a #8AN line size be used as that will be restrictive to the oil flow regardless of the length of the lines.  Treat oil flow just like water or electricity when it comes to flow.  The longer the lines, the more the restriction so increasing the line size becomes necessary.  When using remote filters or coolers, I prefer a #12AN line size and the appropriate larger fittings.
By miker - Last Year
I had a motorhome with oil and transmission coolers mounted well in front of the radiator. It ran about 210 on the water on a long hard pull, and 230 on the oil and transmission. Clever guy I am, I added electric fans to the coolers. At the top of the hill, the oil temps were down around 200. But the engine was over 230 and the red warning light was on. That rig went 75,000 miles, over the Siskiyou pass, the Rockies and the Continental Divide on a regular basis.
One more lesson learned. Leave oil fans turned off. You’re probably fine as is.
By KULTULZ - Last Year
IMO - Rolleyes
Being a MEDIUM TRUCK (F-600), it may well need an engine cooler as to heavy loads, pulling grades, low rear gears and slow road speeds (and the TURBO is also adding heat - and fuel blow-by - possibly thinning the oil).
Is the engine a 292HD?
The best thing to do (IMO), is to install a QUALITY MECHANICAL OIL TEMP GAUGE (along with the QUALITY MECHANICAL WATER TEMP GAUGE I am sure you already have), and proceed from there.
And an oil analysis after every service will also give you an idea of needing a cooler.
And pay attention to TED's recommendation for a larger pan and cooler plumbing.
CLICK HERE - https://www.haydenauto.com/media/5475/oil-cooler-brochure_individual-pages.pdf
Thanks guys. Sorry I forgot about this post until it started running warm again.
I'll get an oil temp gauge and see where it's running. Our heating issues of last fall are largely resolved(we couldn't really run unloaded without temp creep). But hauling in the heat shows we could use an improvement in the radiator side still. I think our El cheapo eBay radiator is just junk.
It's not a 292HD, as far as we can tell it looks like a rebuilt 62 2bbl 292. Probably built in the back of a Napa in Oregon a long time ago.
We have had a ton of fun with it though. It hauls dirt during the week and on the weekends we grab a tent to throw on the bed to go camping haha.
