By geo56 - 9 Months Ago
I am in the middle of a rebuild with parts still soaking. I was lucky enough to have 2 NOS discharge nozzles, given to me by an 88 year old Ford lover who gave me his Holley stash. As careful as I was, I still broke the elbow off of one of the stuck ones. While the carb is apart, I noticed the jet sizes were 50. I happen to have two new unused jets marked 53. I am not a hot rodder and would like the car to be as smooth and efficient as it was when new. I hope someone can recommend which jet size to choose being that fuels are not what they used to be . I will do the Eaton conversion to make this carb compatible with the later distributer. It worked well on a teapot I rebuilt last year. I noticed it has a little click in the throttle shaft. To me , and I am not an expert, it did not seem excessive. I will consider one of the throttle shaft repair kits if it does not idle to my satisfaction. I hope anyone on this site who has done one of the kits will chime in with advice.. I appreciate all the advice I get .
By Ted - 9 Months Ago
If you can post the list number of the carb, I can provide you with what the original jet sizes were. The list number will be at the rear of the carb on the base plate. 50 sounds about right for some of the 1956 carbs. Based on this, I have found that jets that are ~2 numbers richer than stock will help to compensate for gasoline that has 3-5% ethanol. In my part of the country, premium fuel (91-93 octane) has 3-5% while the 87 & 89 grades have the full 10%.
List- 1161 was the number
By cos - 9 Months Ago
Hello If you have any wiggle in primary throttle shaft is sign of wear (usually on left side). I have used them with a lot of wiggle, only effect I had was inconsistent idle. The original bushing are bronze . Replacements are Teflon. Sal (hangs out on Ford barn forum) thought shafts wore more than bushing. Kits are available with or without shafts. But if using just bushing you will have to grinded throttle linkage arm off (left side of carb to get shaft out) and center bore and tap shaft for screw to hold arm back on. Kits with shafts are all ready bored and taped. I would not have done this but planning on boost pressure.
The List #1161 series of carbs all have #50 primary jets. There are actually three of them during the 1956 model year with the numbers being 1161A, 1161-1A, and1161-2A. Another tidbit of information is that those carbs were standard equipment on the 1956 Ford and Mercury cars with the 312 engines. The 292 equipped cars had a different 4V carburetor and the Thunderbirds were yet another number.
Thanks Ted. I'm running a 292 that has the small valve heads and probably started life as a truck engine. Good enough for me though. I think I'll stick with the 50 jets.
For the FYI file. Here’s the list of Holley Teapot 4V (model 4000) carbs showing the factory installed primary jets, secondary jets, and power valve sizes.
List # Pri Jet Sec Jet Pwr Valv Application R-1074A 50 86 43 1955 Ford & Merc 292 R-1074-1A 50 86 43 1955 Ford & Merc 292 R-1074-2A 50 86 43 1955 Ford & Merc 292 R-1075A 51 86 40 1955 Ford & Merc 292 R-1075-1A 51 86 40 1955 Ford & Merc 292 R-1075-2A 51 86 40 1955 Ford & Merc 292 R-1076A 53 120 43 1955 Lincoln, 341 Eng R-1076-1A 53 120 43 1955 Lincoln, 341 Eng R-1076-2A 53 120 43 1955 Lincoln, 341 Eng R-1077A 51 86 40 1955 Thunderbird R-1077-1A 51 86 40 1955 Thunderbird R-1077-2A 51 86 40 1955 Thunderbird R-1078A 50 86 43 1955 Thunderbird R-1078-1A 50 86 43 1955 Thunderbird R-1078-2A 50 86 43 1955 Thunderbird R-1094-1A 60 96 44 1956 Linc & Cont, 368 Eng R-1094-2A 60 96 37 1956 Linc & Cont, 368 Eng R-1094-3A 60 96 37 1956 Linc & Cont, 368 Eng R-1094-4A 60 96 37 1956 Linc & Cont, 368 Eng R-1161A 50 73 28 1956 Ford & Merc 312 R-1161-1A 50 73 28 1956 Ford & Merc 312 R-1161-2A 50 73 28 1956 Ford & Merc 312 R-1162A 50 73 28 1956 Ford & Merc 292 R-1162-1A 50 73 28 1956 Ford & Merc 292 R-1162-2A 50 73 28 1956 Ford & Merc 292 R-1163A 50 73 28 1956 Thunderbird 292 R-1163-1A 50 73 28 1956 Thunderbird 292 R-1163-2A 50 73 28 1956 Thunderbird 292 R-1164A 50 73 28 1956 Thunderbird 312 R-1164-1A 50 73 28 1956 Thunderbird 312 R-1164-2A 50 73 28 1956 Thunderbird 312 R-1268A 48 55 28 1956 Ford T.B. HiPerf, 2-4 Bbl R-1434A 45 55 32 1957 Ford 2-4 Bbl. 312 R-1437A 45 55 32 1957 Ford 2-4 Bbl, 312
By Joe-JDC - 9 Months Ago
Just remember that if you run a 10-15% ethanol gasoline in your vehicle, you may need to jet up a size or two due to the ethanol. If you incur a backfire upon acceleration, or from cold start you may be too lean and need to jet up. Just a thought. Joe-JDC
