cam needed
http://forums.y-blocksforever.com/Topic16719.aspx
By 55Birdman - 17 Years Ago
Looking for Ford camshaft # B7A 6250-C used in 57 engines. Thanks
Is there an alternative cam out there to replace this one?
By Glen Henderson - 17 Years Ago
Give Mummert a call, he used to keep it in stock. His web site states that it is temp out of stock, but they don't update the site often and he may have them again. If not he can tell you if something is available that is close.
By ltman - 17 Years Ago
Bird man are you the 1 that asked me about the cam on e bay
Sorry that was not me.
I do have a couple of those motors complet Ill be disasembling 1 in the next week It may have good cam
By Gordie T - 17 Years Ago
Have you tried Kanter?  www.kanter.com
They seem to have a lot of engine parts.
I will be needing a cam myself for my 58 292 soon.
By PF Arcand - 17 Years Ago
Birdman: Schumann's Sales in Iowa advertised stock of the 57 Cam some time back. Also stocks the Police valve train kits that they recommend with it. Ph#563-381-2416. Fax 563-381-2409. Be careful purchasing a stock cam thru rebuilders & suppliers . Most as I understand it are the mild post 57 - 246 degree units. I've never seen a Mummert ad advertising the 57 spec cam, but he may have it. ?. The closest he advertises is the slightly warmer 265 degree,440 lift cam that he recommends as max if using a Fordomatic.
Birdman: I forgot to mention that Schumann's also stocks what they claim is the correct SAE spec Lifters for Y-blocks. Some off shore lifters sold in recent years, are of inferior quality that don't meet OE standards.. This is just fo info, I don't have any connection with Schumann's..
Guys:
All of your suggestions for cams are good, but what you may have missed is that Birdman was asking for a B7A-C cam, which is the factory cam for supercharged 312s.  Very rare, but I understand Mummert does have a replacement copy of it.
John in Selma, IN
By Ted - 17 Years Ago
Thanks John for clarifying which cam was being asked about.  That definitely redirects the question.
I’ll simply add that in regards to the run of the mill ’57 camshaft, the Isky E-4 when ground on 112° lobe centers comes close to being a nice replacement.  Not quite exact in that it's just a tad larger but has a super smooth idle with enhanced performance.
By pegleg - 17 Years Ago
Mummert does or did list a "C" cam. Also Engle has masters that will allow you closely match the "C" cam, along with matching valve springs. Same as Isky I'd imagine.
By Oldmics - 17 Years Ago
Birdman
We has a great conversation on the cam that you are looking for here
http://www.y-blocksforever.com/forums/Topic8191-3-1.aspx?Highlight=b7a+6250+c
I called Isky to see if an original grind of the 57 cam could still be had and never recieved a response.
For now I gotta get the rest of the parts together before I seriously approach Isky again to grind one.
Oldmics
