By Glen Henderson - 18 Years Ago
I told you guys last week about the B 600 with a y block that I found about 20 miles from me and that I worked a deal with the yard manager. We went after it this morning. after I got it out it was a ECK (55-56) block, O K someone put a car engine in it. We got it home and after I pulled the intake, C1TE heads now what? Pulled the valve covers, and a new set of rockers, I mean no wear at all and clean. Decided to go ahead and pull a head, no wear at all can't even hang a finger nail on the ridge. I had gone to far by now so I fliped it up on the flywheel and pulled the pan. I almost "stroked out", steel crankshaft, .010/ .010 that is as slick as a spanked baby's butt. No stopping now, knocked out a piston, wow C1TE rods. Cleaned the top of the piston and I still don't beleive it, but the dang thing is std bore. The only thing that I can come up with is that it must have eight sleeves or that the rebuilder got hold of some NOS bare blocks. I'll finish tearing it down tomorrow afternoon and find out. CAN'T WAIT
By 2X57SEDAN - 18 Years Ago
wow sounds like youve found a real treasure awesome what are you gonna put it in?
By Ted - 18 Years Ago
Glen. Sounds like a good find. Just shows that getting out there and looking will still find a few good parts to be had. Be forewarned that the steel cranks do not take kindly to offset grinding to the much smaller rod journal sizes if you plan on going that route. I can give more details when the time comes if that’s your plan.
Bummer Ted, that is exactly what I was planing, but no problem I have a std/std cast crank as well. I'll just have to find something else too use the steel crank in. Planing on using the C1TE rods in a 312 for my Fairlane if I ever get time too finish it. If this block checks out I may just build it back for someone else to enjoy.
By yalincoln - 18 Years Ago
hi glen, they used a lot of 256 and 272's in 600 series buses, they may have bored it to std 292 when they rebuilt it, just a thought.
By 46yblock - 18 Years Ago
Taking down one of these old motors is always fun, sometimes exciting or depressing. A "runner" last winter had two broken rods, and was a mess. But still "kind of" fun.
I like taking them apart just to see what someone else has done to them. This maybe a bored out 272, but according to Mummert's chart it is a 55-56 292. I know that others have found things that did not jive with his charts, but it is still the best resource that we have. I have completed stripping it down, just need too remove the galley plugs, and plan to haul it to the machine shop next week for vatting. I am still amazed at the condition of the crank and bearings, this engine had very few miles on it. If it checks out OK it will make someone a good start to a stock rebuild. I'll be hanging on to the crank and rods though.
By mctim64 - 18 Years Ago
Hey Ted, tell me what you know about problems with offset grinding the steel 292, is it all steel 292s or just ones that have had the radius ground out of them? Tim
mctim64 (10/12/2008) Hey Ted, tell me what you know about problems with offset grinding the steel 292, is it all steel 292s or just ones that have had the radius ground out of them? TimTim. For the 292’s I’ve essentially come across three styles of oil paths or drilled oil holes in the crankshafts which is what must be considered if increasing the stroke by lieu of offset grinding. The steel cranks are one of these styles, the early crankshafts with the alternate oil holes at the rod journals is another, and the common fare 1956-1964 cast cranks is the remaining. The later while also being the most common is the easiest to work with in regards to offset grinding to a smaller journal size while taking the journal widths out to 1.800”. This wider journal alleviates having to remove as much material from the replacement connecting rods in order to make them work without having to narrow the rod bearings themselves. The ‘alternate oiling’ crankshafts make nice 2.100” journals while going wider but the oil holes are exposed in the radius when attempting to go to the 2.00” size. The common fare cast cranks make nice offset ground 2.00” journals while making the journals to the 1.800-1.810” widths. The problem with the steel cranks when offset grinding to the smaller journal size (1.889” and 2.000”) lies in trying to make the journal wider than stock. That’s where the oil hole in the crank becomes exposed at the radius and this tends to vary from crank to crank due to manufacturing variability. Some make it and some don’t and that’s with the proper radius being maintained in the fillets of the journal. An undressed grinding rock that removes the radius from the edge of the journal simply compounds the issue. Probably more info than was asked for but felt a lengthy explanation was needed to know that there were some differences in the oil holes themselves which drives which crank can be offset ground the most.
Thanks for the info Ted, I was woried more that you had seen a breaking problem I had not concidered the oil hole. I'm planing on taking a 292 to 3.6" with a journal dia. of 1.888, but I won't be making the journal wider. As you may know we "De-stoked" Charlies crank to get less cubic "s , then I just faced the rods for the proper width of the journal. No bearing problem was to be seen. Tim
Ted: Something you may not be aware of. When I had my 312 crank ground to 2.100, I did not widen the throws, I narrowed the rods to Y width. The crank guy said TRW makes a bearing that is narrower than the stock sbc one for use on cranks with larger than stock radii. I did not use those bearings, I made a fixture from an old sbc rod and chamfered the stock bearings to clear the radius on the crank. Thinking back, I should have bought the narrower bearings, after I cut the chamfer the bearing surface ended up being narrower anyway. John
John. This is a good topic as there seems to be several different approaches on how to get around the journal width issue when using the aftermarket connecting rods in the Y. I have been using the narrower than stock bearings but even at that, the bearings come close to kissing the radius or fillet in the crankshaft if leaving the journals at the stock width. Just getting an additional 0.050” in width at the journal helps in not having to rechamfer the bearings themselves. At this point, I’ve got a reasonably good feel for which crankshafts can stand some extra widening of the journals and those that don’t. For those that don’t, there is just some extra work to be performed on the bearings themselves. I’m still dealing with a generous radius in the crankshaft fillets at this point as gut feel says that there’s a considerable reduction in strength if the radius at the journal edges are removed. Haven’t had a broken crankshaft yet and simply just trying to keep it that way.
Ted, that is no joke about the radius. I've been doing crankshafts for 25 years, when I first started I had a young guy train Me and he was all about doing the job fast, you know "Production". Then I started reading about how cranks should be done, I found the tool for radiusing the stone (it was on a shelf in the shop all covered in dust) and I've been grinding with a radius ever since. The worst thing I see a lot of is some guy will bring me a crank out of his "Racecar" usually a SBC steel 350, and want to have it Maged. The crank will be .010"/.010", have no radius, and have a nice big crack in the fillet on the back side of every throw. A crank that is .040"/.040" is just as good as a Std. (unless it was hardend) but it has to have a radius. Tim
By pegleg - 18 Years Ago
Strictly from a stress standpoint, bigger is better, none, as is mentioned is the kiss of death.
By Moz - 18 Years Ago
my girlfriend keeps telling me bigger is better
By bird55 - 18 Years Ago
John, Ted,Tim-if you guys wouldn't mind I'd like to learn more about the radius topic. I thought I understood at first but now I guess I'm lost. That explains why I'm no machinist, Anyway can someone simplify for the layman?
Alan, At the intersection of the Rod journal to the crank web or throw a radius is ground. This radius is ground into the rod journal to reduce the stress concentrated at the intersection. Sharp edges, particularly on inside corners, are bad news in a casting. By creating a radius you spread the forces out over considerably more area, and reduce the amount at any one point. This actually can apply to main journals as well. A few years back it was all the rage to roll the radius in to the corner, actually deforming the material. This turned out to be a waste of time on cast cranks,but usefull in steel forgings, or billet cranks.
couldn't have explained it beter!
thanks Frank,
So, is this a similar principle of relieving surface stress on other parts by grinding and smoothing or even shot-peening like on rods?
Yes it dose relieve it of stress areas to have a smooth round transition to the bearing surface, It's kinda like when you put a "gusset" on something made of wood or steel. A sharp corner can crack easier than a rounded one.
Alan, Kinda, but even better. A sharp edge puts all the stess at the corner, the smaller the actual corner, the more concentrated the stresses become. Best example I can think of off the top of my head is one sheet of paper is easy to tear from the edge. But if you try to rip it in half from the middle, it's a lot harder. You have spread the force from your hands over a lot more paper. You're dealing with tensile strengths in the crank example. Tensile is the amount of force required to pull a material apart. It's expressed in pounds per square inch. The more square inches presented to the force, the stronger the pull required. It's a bit more complicated than that in a crankshaft, but that's the idea.
Thanks for sharing your knowledge Frank.
See, even though I'm an old dog I can be taught something. It pays to ask questions.
Once again - this place wins my vote!
