Rocker Adjusting Screws
http://forums.y-blocksforever.com/Topic166173.aspx
By oldcarmark - Last Year
Are the self-locking Adjuster Screws and Lock Nut Type interchangeable? In other words can I use same rocker Arm and replace older lock Nut Type Screws with later self locking Type? Is there an advantage to using later style Adjusters? Thanks
By paul2748 - Last Year
Yes - I did just that when I was short of a nut type .adjuster..  The thread in the rockers are the same - it's the adjuster that has the interference threads, not the rocker.  The only possible problem is the length of the interference adjuster in the nut type adjuster - it is very close to being too short, but when I did it it just made it. when setting .019 lash
So the Arm is different between lock nut Type and interference Fit Adjuster?
