By Blind Willie - Last Year
Do any of these linkage parts interchange between 57 Tbird and the 57 full size Fords? I have two 57 Tbird build projects, one manual trans and one manual with overdrive, that are missing some of these. If so, I will make the trek to my favorite vintage Ford salvage yard. Thanks in advance for any assistance!
By 55blacktie - Last Year
concoursparts.com sells parts for both Tbirds and full-size Fords. You could start by cross-checking part numbers to see if they are the same/interchange. It's possible that they use different part numbers for different applications, even though the parts might be the same. You could call/email for clarification, if there's any uncertainty.
By 1/8cavman - Last Year
Blind Willy, after studying my Ford parts Illustrations catalog, the gas pedal #9735, rod #9727, bell crank #9725, pivot #9830, spring #9737, and either #9747 are T-bird only parts, standard and overdrive. The bell cranks attach to the firewall for T-birds, passenger cars attach to the engine. I made automatic linkage parts work with all thread and small tie-rods and springs from hardware parts. If you are looking for authenticity, may be more money. Hope this helps, Good luck. By the way I would buy passenger car parts if the price is right cause they are possibly harder to find.
By KULTULZ - Last Year
If I post the MPC ILL's here (1957 FORD & 1957 BIRD - 312 MANUAL TRANS & OD), will it help if you pick out the PN's you need and I will cross-reference them?
Thanks to both 1/8cavman and Kultulz. I had a feeling the linkage parts were largely unique to T-bird, such as the bell crank and pivot. The long rods that make the final connection to the 4 bbl carb might interchange with passenger cars or trucks. Hill’s has most of them (new and/or used) and their catalog has good diagrams with numbers. I think I’m good for now! But thanks for chiming in.
