WTB Engine side bracket for Z-bar
http://forums.y-blocksforever.com/Topic165114.aspx
By cos - 3 Years Ago
Hello Members  Looking to buy a engine side bracket for Z-bar on 57 ford car. (292)  believe part number is B7A-7509-A. It is  pressed steel and mounts to bellhousing. Mounting holes are 2.65 "OC and ball OD is about 27/32". I have WTB ad on other Ford forums.  Cos 541 221 7941 call/text/PM. Thanks  Also need adjusting rod from Z-bar to throw out fork and U shaped stamped steel retainer that clamps rear transmission mount to transmission.
By Ted - 3 Years Ago
I may have the Z bar engine block mount that you need.  Not sure what year or if a car or pickup application for this one.  The ball diameter is 0.840” and the ball aligns with the top mounting hole of the bracket.  Here are some pics.  Email me if interested.  Email address can be found under the ‘Contact Us’ tab at www.eatonbalancing.com   .
http://forums.y-blocksforever.com/uploads/images/f0fe7871-af91-434c-b23c-86e4.jpg
http://forums.y-blocksforever.com/uploads/images/50a7158d-ef8b-4cb0-89b1-b7a5.jpg
http://forums.y-blocksforever.com/uploads/images/f1a8d3b8-814f-4837-9baf-9c8b.jpg
Thanks Ted   I have one like yours, not in as good shape as yours. Mine bolts to block fine but ball is to high (not level with z-bar) and sticks out  to far.  Could probably make it work by pressing ball out and fill in swallow area and remounting it down. Then eglong mounting holes to move bracket in toward engine.  Part of problem finding one, I don't  know what Iam looking for. Thanks for quick reply. Cos   Oregon
