temp sending unit on 312
http://forums.y-blocksforever.com/Topic164637.aspx
By stbart - 2 Years Ago
I ordered a temp sending unit for my 1956 Mercury, the description said for 1956 Ford car but it is the wrong thread. The new sending unit is 3/8 NPT but the hole in the head is 1/4 NPT. I read an old post on here that mentioned that the 1957 is 1/4 NPT.  Can someone please confirm that. If it is, then I will just order a 1957 temp sending unit. I do not want to start using reducers/adapters. Previous owner had installed a mechanical gauge with adapters. I have verified that the gauge in the dash works, so I want to put an original type sending unit back in. I have already installed a mechanical gauge on the front of the engine in the hole for the heater return hose just before the thermostat.
Is the 57 sending unit 1/4 NPT?  If not, what sending unit do I need?
Thank you for any tips.
By Ted - 2 Years Ago
The 1954 thru 1956 Y cylinder heads use a 3/8” NPT thread at the temperature bung.  The 1957 thru 1964 Y cylinder heads use a ¼” NPT thread for the temperature sending unit.
The 1956 12 volt temperature sending units are unique as 1956 is a one year only item due to the electronics for the temperature gauge being different electrically from the 1957 and up units.  To use the correct 1956 temperature sending unit, you will need to change the existing ¼” NPT bung in the cylinder heads to the 3/8” NPT unit if retaining all the original 1956 gauges and wiring.
More comments always welcome.
Thank you for the info. I now have a decision to make, I don't want to do anything to risk damaging any pieces or parts. I did read another post about changing the bung. At least I know what has to be done. I have it installed now using reducers/adapters and a coupling, just as it was when I got it, but the problem is that it sits above the manifold and not in the water flow. It takes forever for it to read above cold. I have not looked at all yet but is a new bung easy to acquire? Who is the recommended source? Any tips for removing the current bung? Do they pop out fairly easily?
By 55blacktie - 2 Years Ago
stbart, the outside diameter of the bungs are the same. You can get the 3/8, 55/56 bung from Hill's (www.hillsresto.com). The part number for the 3/8 bung is 10911-AR. The price is $15, excluding shipping. Hill's probably will ship by USPS (saves money). No tax if you're outside Ohio. Your sender and gauge should be a matched set.
I have removed/installed a number of those temperature sending unit bungs to either get to the correct NPT size for the sender or to convert a right-side cylinder head for use on the left side of the engine.  Some of those bungs were in tighter than others and I’m sure that rust and time are big players for this.  To date, I have always had the heads off of the engine in which to accomplish this.  For this, I simply used a slide hammer affair with a ¼” or 3/8” pipe nipple on its end.
While I have not changed out the bung with the head on an engine and in the vehicle, I picture it being doable.  The intake manifold being removed would definitely help in having enough room in which to accomplish this.  Depending upon the hood or firewall clearance, a slide hammer affair would get the job done.  I can also picture making a special puller that would use a large diameter bolt welded to a pipe nipple and that bolt being threaded through a 4” tall hollow cover in which to pull the bung out of the cylinder head.  Installing the new bung would be just a matter of tapping the bung in place with some sealer around its outer edge.
Always be sure that the ‘wide’ end of the NPT threads is facing out and not in when installing the bung; otherwise, the temperature sending unit will not thread into the bung.
This thread has me confused. My 6V/292 ‘55 T-Bird has replacement (post ‘56) 113 heads.  I have had to replace the sender before (NOS/6V part), and it screwed right in with no issues. Does that mean the Ford dealer mechanic who changed heads back in the 60s/70s must have used some kind of thread adapter?
They either used a thread adapter or swapped the bung.
By Marc - 2 Years Ago
Concours parts sells the bung and a tool for removing the old bung. I just used it to remove the bung from a G-head. Very easy to use, no problems. As Ted said, just put a little sealer on the new one and tap it in.
Now I'm confused. The 113 heads originally would have used the smaller 1/4 NPT 12v sender. You said that you had screwed in the 6v (3/8) sender with no problem. Unless I missed something, that means the bung was swapped from 1/4 to 3/8, then swapped back to 1/4, and now you want to swap back to 3/8. Am I missing something? Although the 55 & 56 senders are both 3/8, the 55 is 6v and the 56 12v.
By paul2748 - 2 Years Ago
55blacktie -you are confusing two different people The original poser is not the one that mentioned the 113 heads..stbart had the original question, Daniel Tinder mentioned the 113 heads
quote]55blacktie (6/25/2023)
[/quote]
I changed the bungs while the heads (and intake) were still on the engine and the engine was in the car.Not really difficult, but I did have to move/remove some of the gas pedal  linkage to do so.  I used the tool from CASCO to remove
Paul, if you reread Daniel Tinder's last post, maybe you'll have a better understanding of mine.
Sorry if I contributed to the confusion.
DANIEL TINDER (6/25/2023)
Looking at the Ford parts catalog, there were not separate part numbers for the left and right side cylinder heads.  This leads me to believe that the bungs and freeze plugs were not already installed in the replacement heads and were either included loose with the heads or ordered separately.  It was then up to the installer to put the freeze plug and/or bung in their appropriate locations.
Assuming the 113 heads originally came with a ¼” NPT bung for the temperature sending unit, the dealer likely just changed out the existing bung to the correct 3/8” NPT bung for installation on the earlier engine.
This likely must be an issue I dealt with in the past, but has totally escaped my memory.  The ‘G’ heads I installed on my back-up motor wouldn’t have been left uncompleted, and I’ve always intended to retain the 6V system.  I’ll have to double check that detail wasn’t overlooked though, by trying to screw in a 6V sender (been putting off the engine swap BTW for many years, but since orig. block’s 10W-40 oil pressure is now barely keeping the 10#-per-1000rpm minimum, it probably won’t be long).
DANIEL TINDER (6/26/2023)
This likely must be an issue I dealt with in the past, but has totally escaped my memory.  The ‘G’ heads I installed on my back-up motor wouldn’t have been left uncompleted, and I’ve always intended to retain the 6V system.  I’ll have to double check that detail wasn’t overlooked though, by trying to screw in a 6V sender…
Yes, was done.  Sorry for the memory lapse (Geez, don’t get old).
