55 56 T-Bird (and maybe passenger car) speedometer housing clips
http://forums.y-blocksforever.com/Topic164341.aspx
By 312YBlock - 3 Years Ago
I understand these clips were used to connect the speedometer cable to the speedometer housing on 55 56 T-Birds and probably passenger cars. I spoke to Hill’s T-Bird parts, they have the clip in stock but the parts person i spoke to said he didn’t know how to connect it to the cable. Does anyone have knowledge of this?
By Hoosier Hurricane - 3 Years Ago
The clip pictured goes on the tip  of  the speedo  inner cable and inserts into the speedometer head.
By paul2748 - 3 Years Ago
You may not have this clip if the cable has been replaced at some point.  Some replacement cables have the usual square end instead of the clip.
Hi HH, what is the mechanism that secures the cable to the clip?
The top end of the cable core would have a flat tang on which the slotted end of the rubber connector fits.  The "square" on the other end goes into the speedometer.  Replacement cores would have the conditional square end and would not use the adaptor.
Thank you HH, I appreciate the insight 😊
Thanks Paul, I just received the clip today, the cable just plugs into the end. My speedometer is working fine without it, I’ll put it into the glove box for now 😊.
