Looking to buy air ffilter for car with S/C
http://forums.y-blocksforever.com/Topic164195.aspx
By cos - 2 Years Ago
Hello Members  Looking to buy air filter for a car with S/C. Also end plate cover for same air cleaner.  Cos  541 221  7941 PST
By Hoosier Hurricane - 2 Years Ago
cos, are you looking for an air filter element or a complete filter  assy?  I have an old used NAPA 2901 and a used original element.  They are both in Big A (Autopro -are they still in business?) boxes with number 93245.  They compare exactly the same in OD, ID, and length.  However the NAPA filter has  metal end caps  where the original has rubber caps.  A thin sheet of rubber could remedy that.  Hope this gives you a couple of part numbers to try to  interchange at your local store.
Thanks Johns for Info. Will check out. Is it OK to send you a PM or E-mail? Cos
cos, PM or email are OK.  I sometimes fail to check PMs very often.  Email feistritzer1(at)msndotcom
