By 428kidd - 2 Years Ago
As the title says I have a factory Ford 312 dual quad 2x4 set up . I believe this is correct for a E code thunderbird, but should work in a full size car or what ever you want to install it on. Has a ecz 9510 b carb which is incorrect , but they say one of the best ones to use on a 2x4 set up. Also has a correct ecj 9510 ab carb which is correct for the set up. The intake is a ecg 9424 d. It has the bell crank, linkage , firewall bell crank and mouse trap all shown in pictures. Intake has no issues or repairs , other than a little porous above where the casting number is. This shouldnt be a issue as it was removed from a non E code car and correct 4v replaced it before selling it. The correct air cleaner is also there and everyone knows probably the hardest most expensive part. It is very nice on the out side but not perfect on the inside. It does however look very nice. It has had a repair in times in the tops and spot on the inside before it was chromed the last time. Also the front on the air cleaners can't be read very well due to the chroming process. It is a old chrome job but still shines very well and could be cleaned even more. Like I said this was removed from a running engine, but not sure how long ago. So it will need gaskets and probably the carbs gone through . Comes as pictured, sold as is where is. Very nice hard to find complete unit. $SOLD shipped to lower 48 states . If I got any of this wrong I'm more of a FE guy , so just a heads up. Fell free to contact me 931 three one nine zero six 85.
By PF Arcand - 2 Years Ago
That's certainly a nice unit & clean At this point in time, finding someone other than someone doing an exact restoration of an E code car or T.Bird may be difficult. It's also difficult to find someone who will tacke those old style carbs.. You might want to contact a T. Bird club or advertise somewhere with more general Ford coverage.. You may know this or not, but for Hot Rod /Custom car guys, there is relatively new parts such as offered by "John Mummert" Machine, ( see Link from this site ) that perform as well or better than the original parts, which makes your sale even more difficult... Good luck..
Thanks , this is not targeted toward hot rod or custom guys really , and I understand there are better performance options available today. This is what it is and stands on its own merit , it is also sold . If that changes I will let everyone know thanks .
