Rocker arm adjusters
http://forums.y-blocksforever.com/Topic162684.aspx
By glrbird - 3 Years Ago
Can you swap set screw/ lock nut adjusters with the interference fit adjusters on the rocker arms
By paul2748 - 3 Years Ago
Yes you can - I had to do it  for one valve.  However, depending on the push rod, it may be tight to get the .019 gap.  When I did it, it was close, but worked. The interference thread  is in the adjuster, not the rocker arm.
The adjuster and the lock nut are available - Mummert has them, just saw his video
thanks for the info.
I only use the adjustable lock nut style on all my engines. Just remember when you have what you thing is perfect after you tighten the lock nut it will be loose about .001”.
By DANIEL TINDER - 3 Years Ago
I have interference AND locknuts (belt & suspenders). The added valve gear weight is likely a viable trade-off for maintaining an accurate gap for longer (?). I also think a long hex wrench is easier to use than a screwdriver if you want a precise adjustment.
By SWinner - 3 Years Ago
Can anyone let me know of a source for the interference type of adjusters?
By Ted - 3 Years Ago
SWinner (12/20/2022)
While I do not have a source for new interference fit rocker arm adjusters, Smith Brothers Pushrods does offer a set of jam nut adjusters for $108.  If it helps, the Y adjuster is the same size as the adjustable rocker arm adjuster for the Ford FE (352/290/406/427) which may help to broaden your search parameters.
For those using both or just wanting to lighten up rockers; you can use “pal” nuts which are less than 1/2 the thickness of a regular nut or make them from aluminum. I made the ones for my GMC 6 race engine. Bought hex stock, drilled and taped for the adjuster, and cut them on a lathe.
