Exhaust
http://forums.y-blocksforever.com/Topic162275.aspx
By Bobby O 55 - 3 Years Ago
         How many gaskets should I use from the exhaust manifolds to the pipes. I was going to order some gaskets and some companies said 3 req'd. Is this true. What do I need. I have a 272 y- block. Thank You.
By Joe-JDC - 3 Years Ago
One on each side of the heat riser spacer/block, and one on the driver's side.  Three total if stock exhaust system.  Joe-JDC
I don't have a heat riser/block. So that would mean one on each side correct.
Correct.  Joe-JDC
   Thanks so much.
