bought 1 just about had big fire,secondareys pucking gas, then backfire. no real damage. amezon completely let me down..has a supposed warranty threw Holley reinstalled my refurbed Holley 600cfm all is well.. it came from Holley as a repaired new 1. I found amezon hard to deal with technical issues. returns are the only way to go.could not get info to them. canceled my account supplier out of Edmonton Alberta sent me a new needle and seat(no charge swill fix myself. not Suer but brawler 4v is made in china .have indicators they are problem child
According to the Holley website Brawlers are machined and assembled in the USA. Die castings have been used forever so it might just assembled incorrectly. Some carbs have been flow tested before shipping. My new Summit was for sure. Not sure on Holleys or Edelbrocks. I’ve found Amazon ez to return parts as long as I’ve received a service number from them. I do it at a department store near me.
found the problem, removed 2ndary float and bowel. all the tapered screws holding the small plate wher loose.. so much for assembly and flow test in america. the big issue is lack of help from amezon. no longer will be dealing with them
By paul2748 - 3 Years Ago
I don't understand why you think Amazon should be offering technical advice. They are a retailer who does not build or repair cars. You beef is with Holley, not Amazon. Never had a problem returning anything there.
amazon took my money, they enitionly excepted replacing the carb, then send they wher not available. then when 1 was avail, they send I did nor react with in ther warranty window. evatualy the seller to amezon agreed to return my money(but only what amezon paid them. I asked is they would send me a gasket and a new vac for 2ndary float.the agreed and I repaired the carb. SO MY FREND SOME TIMES AMEZON RESPONDS,SOME TIMES NO.
6 MONTHES AGO I ODERED A TRAILER HITCH,RECIEVED 6. EVENTIONLY THEY ADMITED THE ERROR WAS THER SUPLYER AND TOOK 5 BACK. THO THEY CHARGED ME 40 DOLLERS FRT. MR BAZEL RUNS A MARGENAL GRP OF I WONT SAY ANY MORE. JUST TRYING TO WARN FELLOW USERS
WOW
2721955meteor (7/24/2022)
amazon took my money, they enitionly excepted replacing the carb, then send they wher not available. then when 1 was avail, they send I did nor react with in ther warranty window. evatualy the seller to amezon agreed to return my money(but only what amezon paid them. I asked is they would send me a gasket and a new vac for 2ndary float.the agreed and I repaired the carb. SO MY FREND SOME TIMES AMEZON RESPONDS,SOME TIMES NO. 6 MONTHES AGO I ODERED A TRAILER HITCH,RECIEVED 6. EVENTIONLY THEY ADMITED THE ERROR WAS THER SUPLYER AND TOOK 5 BACK. THO THEY CHARGED ME 40 DOLLERS FRT. MR BAZEL RUNS A MARGENAL GRP OF I WONT SAY ANY MORE. JUST TRYING TO WARN FELLOW USERS
By PF Arcand - 3 Years Ago
..After reading all the preceeding, I suspect the main problem is a communication issue.. It's a good idea to re read carefully all communications "before" sending them.. Just typing a communication & hitting the send button isn't a good idea. I know from experience!...
