Good choice for a street able 4-barrel carburetor for a1957 pretty stock 292 that is bored .030" Don't let all worms out of the can
http://forums.y-blocksforever.com/Topic161618.aspx
By Melly - 4 Years Ago
Just want a carburetor for a 1957, 292 ci with a 1957 Distributor, B-manifold and G-heads (I am told-???)  Something that just works well as I use it only for summer fun here in MN. Then store it in a igloo.   I have read many articles and just get confused so figured that those driving them would be a better source.  Thanks in advance.
I've been using Holley Street Avenger carbs for the last 12 years or so.  The first lasted about 10 years, daily driven all year, without any rebuilds or cleanings.
The Summit carburetors work great and provide some higher end features for a very reasonable price.
By 55blacktie - 4 Years Ago
I bought a refurbished Holley Street Avenger 570 carburetor, but it's still in the box. The Holley refurbished carburetors are carburetors that have been returned to Holley. Often there is nothing wrong with them when they are returned under warranty. Holley inspects them, makes any necessary repairs, and sells them at a significant discount. The refurbished carburetors come with the same warranty and accessories that are included with brand new carburetors. If a refurbished carburetor is not in stock, you can sign up to be notified by Holley when one is available. If I hadn't bought the Street Avenger, I probably would have bought a Summit 500/600 cfm, the latter of which probably will require smaller jets.
By the way, Ford Performance equips its $10,000 306 crate engine with the Street Avenger 570.
By Joe-JDC - 4 Years Ago
For a fairly stock 292, I would suggest the Summit 500VS carb if your engine has hood clearance for a modern air cleaner.  It will not work with a drop base style air filter/cleaner unless you use the 3" filters.  Will not work with the Thunderbird air cleaner.  Joe-JDC
By Ted - 4 Years Ago
Here’s the link to a past thread which may prove to be helpful.
Carburetor Sizing (y-blocksforever.com)
By Deyomatic - 4 Years Ago
I have a new Holley 1850 (600 CFM) that worked great out of the box on mine.  Supposedly a '59 vintage.  Spark plugs look nice so I didn't even need to mess with jetting.
how about the Sumit m08600va 600 cfm carb.  any thoughts?
Melly (7/8/2022)
how about the Sumit m08600vs 600 cfm carb.  any thoughts?
From a previous thread where I posted the following:
I have installed a large number of the Summit carbs on Ford Y engines with the majority of them being the 750 version.  Have installed a few of the 600 cfm versions with no obvious out of the box issues with those.  Both the 600 and 750 versions are jetted reasonably close for 700 feet above sea level but I can envision leaning the jetting either for higher altitude or extremely hot weather.
As a general rule, it’s hard to go too big with a vacuum secondary carburetor.  The secondaries open only the amount demanded by the engine assuming a stock secondary spring is being used.  The 750 version when running with just the primary side is like running a typical 350 cfm 2V carburetor.  Any air flow sizing of the carburetor above what the engine requires will simply have the secondary side not opening fully in which to compensate.
http://forums.y-blocksforever.com/FindPost161256.aspx
The Summit carbs do use the same fuel needle seats, jets, and power valves as the standard fare 4150 and 4160 Holley carburetors.  That particular line of carbs incorporates annular discharge nozzles for the fuel which gives improved atomization of the air/fuel mixture as it enters the air stream.  Servicing the carbs is relatively easy as the top of the carburetor is removed to access the jets.  The fuel reservoirs on those carbs are amply sized thus allowing those carbs to sit for longer periods without the fuel levels being diminished as quickly due to evaporation.
I do have the Summit 500 cfm version on my ’55 Ford and while it is a good driver, that carburetor is still undersized for a lightly warmed over 272.  For most stock Ford Y applications, the 600 cfm version would be a good all around choice.  For any Y engines with upgraded camshafts, larger valved heads, improved exhaust, and the other typical performance mods, the 750 Summit carburetor is my carb of choice.  The 600 and 750 versions are jetted very close as received and typically may only require a slight fuel mixture adjustment after setting the idle speed.
http://forums.y-blocksforever.com/uploads/images/d2add656-9537-4bc3-b2e9-2b7d.jpg
By RB - 4 Years Ago
I have tried Summit,Ebock, and latest is the Demon 600 street carb from Holley  I like the demon the best.. great throttle response good idle and it gets better mileage than the other 2. It has small primaries which give the throttle response and mileage.. I bought mine direct from Holley as a refurb for cheap, but I see now they are within a few bucks of the other offerings.. I highly recommend them.. Mine was great out of the box. My motor is a standard 292 with Joe heads and a 312 intake and headers.. Smallish cam. 1800 stall converter and stock gears.
Every modern 4-barrel carburetor I've looked at has a manifold-base-to-air-cleaner-base height of 3.25-in. A summit 14" drop-base air cleaner/w 3-inch element provides enough hood clearance for my Street Avenger 570 carburetor and a 1/2" carburetor spacer on my 55 Tbird. If you have a truck/full-size car, hood clearance shouldn't be a problem. If I remove the spacer, I have just enough hood clearance for a 14" oval air cleaner/w 2" element. The oval air cleaners do not have a drop base. The drop-base air cleaner, to an extent, hides the carburetor; whereas, the oval air cleaner sits on top of the carburetor.
By the way, there's nothing fancy about the Summit air cleaner, but I paid $29. It's a chrome, open-air sheet-metal air cleaner/w no logo (which I like). If you experiment with different element heights, you need to allow for sufficient clearance between the float-bowl vents and the air-cleaner lid, regardless of carburetor/air cleaner brand/style. Using any less than a 3" element on the Summit air cleaner put the lid too close to the bowl vents. The oval air cleaner's 2" element is not a problem.
I like the idea of smaller primaries for better throttle response at lower rpm and increased mpg. The Street Demon, however, didn't perform as well as other carburetors tested (including Summit's) on an episode of Engine Masters, but keep in mind that their focus is on max torque and horsepower, which is not necessarily the best indicator of how a carburetor will perform at various rpm on the street. Testing an engine on a dyno, under ideal conditions, is not a fair comparison.
By Florida_Phil - 4 Years Ago
I have a Holley 1848-1 465 CFM carburetor on my .060 over 292.  My engine has similar modifications to yours and is street driven. I chose this carburetor for a number of reasons.   I like the original look.  This carburetor is almost identical to the carb used on 1957 D code 312s. I am familiar with Holley carbs as I have been using them since I got my license in 1963. They are easy to tune, parts are available and they run great.  The other reason is this carb tested near the top of Ted Eaton's Y-Block dyno testing.  This did not surprise me as I am very pleased with it's performance.  A few other comments.  Throttle response is fantastic. This small 4V works perfect on a 292. I am running the stock jetting and secondary springs. My only modification was to install a manual choke.  My plugs are light tan and never foul.  Many of my friends run Summit carbs with good results.  I like the way my Holley looks and performs.
http://forums.y-blocksforever.com/uploads/images/0c475015-0303-483a-bcae-5df6.jpg
I have installed the Street Demon 625 carbs on hopped up Y engines and like RB says, they do perform very well while also providing excellent fuel economy.  These carbs are available as either 625 or 750 cfm versions but for most Y engines, the 625 version is expected to be adequate for most applications. Those smaller primary bores do give enhanced low-end characteristics while also improving the atomization of the fuel for economy purposes.  The Street Demon carbs are available with either aluminum or composite plastic fuel bowls.  To date I have used only the carburetors with the composite plastic fuel bows as those do keep the fuel cooler and reduces the chances for any ‘heat soak’ that may be present.
These carbs are considered being three-barrel carburetors but unlike the older Holley three barrel carbs from the Sixties and Seventies, the Street Demon incorporates what is called a ‘Goggle’ valve for the secondary throttle blades.  While those older Holley three-barrel carbs required a slot in the primary divider in the dual plane intake manifolds, the ‘Goggle’ valve does not require that slot or similar modification to allow the secondary throttle blade to open freely.
While the Street Demon carbs have a very clean look to them as a result of no exposed screws on their tops, this feature does require the carburetor to be removed from the engine for any jetting changes.  While the supplied jetting is reasonably close out of the box, jet and/or metering rod changes will require that the carburetor be disassembled by turning it upside down to access the necessary screws.  The primary jets and metering rods for the Street Demon carbs are specific to those carbs and not interchangeable with other carbs.  But once jetted to your particular requirements, the Street Demon carbs are both good performers and trouble free.
Here are some pics.
http://forums.y-blocksforever.com/uploads/images/a03870b9-9623-43f7-bd74-a0bb.jpg
http://forums.y-blocksforever.com/uploads/images/0d2b433f-8a5e-4ca7-ba84-f727.jpg
http://forums.y-blocksforever.com/uploads/images/583ded25-f47a-4ada-9cfa-2b2c.jpg
To all the Great Y blocker who replied with great helpful information I say Thank You, but I have to confess I am at the bottom of the pole when it come to my old Y block!  My confession is that I overlooked the basic. It turned out that it was the distributor cap had hair line cracks. I look at it many times but not till I took a photo and enlarge it did I see them.  Had a new cap on shelve put it on and it now runs like a top. I can't tell you all that I put so much blame om the Summit M08600vs carb.  I can now say that that was a great choice. and will contact Summit to apologize to support people.  Old age is the only thing I can maybe blame.  Thanks again you all are great, and the group is very helpful.  Keep it up.
By BKernell - 4 Years Ago
I have a Quick Fuel 450 CFM that I bought from Summit, works great on my 56 Victoria 292ci and gets decent fuel milage also it's new not rebuilt.I had intended to install 2x 4s but changed my mind so I still have one new in the box I would sell if you are interested just pm me
By Daniel Jessup - 4 Years Ago
With my Summit Gift Certificate from Fast Fords and the Y Block Shootout, I ordered one of these carbs as well. However, I went with the 500 cfm version. I will check through things on my 292 and then probably save it for my 272 I have in the shop in North Carolina. I do recall that the 500 cfm Edelbrock I had on the 292 before switching to the Holley was prone to heat soak, the Holley not so much. It does look like it is easier to tune the Summit carbs than the Holley's due to the fuel bowls being integrated into the main body. I am forever going through the fiber washers for the 4 bolts that secure the bowl to the base, and at times going through the metering block gaskets is a chore.
I am sure you would be happy with the 500 on the 292 also. Smaller Venturi’s bring a better vacuum signal along with annular discharge boosters will increase bottom end and work best where we all drive our cars. My engine rarely sees 3000 rpm and that’s in second gear on an on-ramp. Even at highway speeds of 70-75 I’m at 24-2500 rpm. I’ve always used phenolic spacers under my carbs.
Florida Phil helps prove my point by using a 465 cfm for its street ability.
