By paul2748 - 3 Years Ago
Seen this on another site. I guess it's to get the oil down to the pan quicker or lube the cam better. Weaken the block??
By Joe-JDC - 3 Years Ago
Just my opinion, but on my blocks, we drilled a small 3/16" hole aimed toward the camshaft lobe on the side that keeps the oil away from the center of the engine, and creates less windage. You don't want the oil from the camshaft area to be thrown back up into the valley and create more aeration for the PCV to pick up. You need a certain amount oil to stay in the valley area to keep the lifters cool and properly rotating, as well as lubricating the pushrod ends. There is a large area at the rear of the valley for oil drain back that also keeps the distributor gear oiled. You don't want to take that away and let the distributor gear run hot. Joe-JDC
By PF Arcand - 3 Years Ago
Eickman's Y-Block book, (1984) suggests drilling & chamfering the block, but not to that extent! Holes that big likely do weaken the block. And as Joe JDC says, some oil is needed up there. It's likely those big holes result in excessive upwards oil spray.. FWIW I wouldn't do it..
By Ted - 3 Years Ago
While the Ford Y block is considerably stronger than the oem SBF and SBC blocks, they are still prone to breaking down the middle when extreme horsepower is being thrown at it. As Joe mentions, I too will do the 3/16” holes in the valley to help with some additional oil flow back to the camshaft lobes. A chamfer at the top of each added hole aids in the valley oil actually making it into the hole. Here’s a picture.
I did dyno test a 400+ HP Y a few years back on the dyno with a clear cover over the valley and saw an extreme amount of oil being pushed back up into the valley as pressure was being generated in the lower crankcase area. The holes in that particular block were done as illustrated in the Eickman Ford Y book. Here is a picture of a block recently supplied for a rebuild that was drilled and grooved as per the Eickman example.
With that in mind, it is best to be cautious on the both the number and sizing of the holes that are drilled into the valley to supplement any oil that goes back to the camshaft. Any holes drilled or machined into the valley does weaken the block. Likewise with any grooving that is done in the valleys to help direct the oil to the block such as is shown in the Eickman Ford Y-Block book. Those extreme modifications have not posed any issues on the lower horsepower combinations but they are best avoided when considering above normal horsepower modifications. For the run of the mill and up to 500 HP engines, problems are expected to be minimal from the additional valley holes. For the 600 HP applications, any modifications to the valley must be prudently thought out as those additional holes are potential locations for block breakage to start from.
It looks like their inspiration may come from Keith Dorton.
By 55blacktie - 3 Years Ago
Is the y-block oiling problem so severe that these modifications are necessary?
What Ted outlined with the holes right down the center is probably the most that should be done. All of that extra plumbing, not necessary and more possible points of failure.
No, the oiling in the Y is not that problematic with current oils. If you ever get a chance to see a V-8 engine's lower crankcase while the engine is running, you will be astonished at how much oil is being slung around by the 12 bearing edges on the crankshaft. (2 rod sides and middle/per journal). The idea is to get more of it away from the camshaft, not put more there. Getting the oil away from the crankshaft by using a deeper oil pan and scraper helps with reducing windage power losses. Jay Brown on his FE forum put a plexiglass window in his FE dyno oil pan to watch windage and oil level drop during a dyno pull. The engine sucked/whipped up 5 quarts instantly, and aerated the remaining oil and return so badly it looked like foam for several seconds after shut down. The only way to stop that was to deepen the oil pan a couple of inches so that the crankshaft didn't whip up the oil in the pan. A windage screen seems to work better than windage tray louvers, at least on the FE. Joe-JDC
By bird55 - 3 Years Ago
And my understanding is that a dry-sump system accomplishes similar things as well depending on the application?
55blacktie (3/11/2022) Is the y-block oiling problem so severe that these modifications are necessary?
You gotta love it when a C H E V Y guy thinks he has the fix for what is a perceived oiling deficiency in an engine. Obviously overkill and will very likely cause more problems down the road as it ages. The oiling system for the Y is more than sufficient for the rod and main oiling as the stock oil pump was over-engineered from a standpoint of volume. The lack of oil changes and the use of poor quality oil though did bring forth some top end oiling issues on the Y engines back in their day. With several examples of +300K mile engines still on the road, the factory oiling system was more than adequate with quality oil and regular maintenance. Ford did wrestle with how to transfer the oil to the top end at the center cam bearing though as it started out as cross-drilled camshafts in 1954, switched to grooved camshafts in 1956, and then back to cross-drilled camshafts again in 1963. For today’s Y builds, the latest crop of cam bearings with a softer material and shallow grooved camshafts brings those top end oiling problems back to the forefront. There are several fixes for ensuring that the top end oiling issues do not crop up on a fresh rebuild with some of those being grooving the center cam groove deeper, using a center cam bearing with an external groove, or just machining the center cam hole in the block similar to what FoMoCo did for the top end oiling for the FE engines. Here is a link giving more information on the top end oiling issues related to the Ford Y.
Y-Block Top End Oiling Woes – Eaton Balancing
bird55 (3/11/2022) And my understanding is that a dry-sump system accomplishes similar things as well depending on the application? A dry sump oil system does eliminate many of the windage problems that are related to running with a higher level of oil in a wet sump oil pan. I have a dry sump system on my Y powered roadster as the engine is mounted very low in the chassis which creates some challenges in running an oil pan with a sump that’s deep to compensate for the oil movement when both speeding up and slowing down. The oil pickup could be moved around to accommodate either acceleration or deceleration but not both due to the shallow depth of the pan. A dry sump system solves that as the oil pan can be made very shallow and essentially has no oil in it during normal running conditions. A three stage pump is used where one stage supplies oil to the engine and two stages keeps the oil pan sucked dry of oil. A plus to the dry sump system is that the amount of oil could be reduced from 9 quarts to 5 quarts of oil which allows for a quicker warm up. The dry sump oil systems do take a considerable amount of room though to accommodate both the pump, belt, hoses, and an externally mounted oil reservoir.
