55 Fairlane stuck rear drum
http://forums.y-blocksforever.com/Topic159932.aspx
By TNieland - 3 Years Ago
Parking brake cable is removed drum spins but won't release from hub any information is appreciated
By panel driver - 3 Years Ago
Try taking a hammer and striking the face of the drum. Lubricate where the drum slide over the axle, assuming its a rear drum.  Hope this helps.
By carl - 3 Years Ago
Back the brake shoes off as much as you can.they might have a lip worn  on the outer edge of the drum holding it on    Carl
Thanks Carl that worked
