By bergmanj - 4 Years Ago
Hi! Am reconditioning a 1955 Ford car speedometer & am aware that they originally probably used fine whale oil for lube as it does not gum-up nearly as fast as mineral oils. Does anyone have advice as to what modern (synthetic - ??? / other???) lubricant can be used in it's place?
Thanks, JLB
By paul2748 - 4 Years Ago
I use a light machine oil, like 3 in 1 oil. Go easy on the oil
By Daniel Jessup - 4 Years Ago
Ditto to what Paul said, you can also visit my website blog pages to see what I did on this for my 55 Ford Club Sedan... the link is
https://www.hotrodreverend.com/post/2018/07/14/1955-ford-part-56-speedometer-and-odometer-reset
I was taught to use lubriplate. If possible I pull out the cable and clean it thoroughly then apply the lubriplate along the entire cable twisting it as it’s inserted. They have always been smooth for as long as I owned the vehicle.
Paul, Dan, I have used 3-in-1 previously (also a mineral-oil derivative); and wanted to find a non-mineral-oil alternative that is much less susceptible to oxidation, volatiles evaporation, and consequent gumming long-term, as the fine whale oil lube that was originally used. That's why I was wondering about any modern products that would gum less with time.
DLR, I do appreciate your "input"; the question was about lube for the actual speedometer internals, though. I'll keep the "Lubriplate" in-mind for future cable lube, though.
Any others?
Thanks much, JLB
I too have always used a high quality light mineral oil. A drop or two at the bushing where the cable attaches will take several hours to soak in. Search the internet for a good high quality clock oil. Synthetic is readdily available and I would think this would be your answer.
By Joe-JDC - 4 Years Ago
Dorman makes a speedometer lubricant specifically for speedometer cables. Dorman 9-1812 Grease & Lube. Joe-JDC
By 312YBlock - 4 Years Ago
I made the mistake of applying Lubriplate to the steering column shaft back in 85. A number of years later the telescopic feature seized up. After pulling it I found the lubriplate had solidified.
By Tedster - 4 Years Ago
I suspect what you want here, what is basically a clock oil. (Yeah, he's not talking here about lubing the cable itself).
What you'll find is (synthetic) Mobil 1 is very much favored by the professional clock repair guys in lieu of expensive, bespoke dedicated $$ clock oils, particularly because it does not gum up.
Thanks guys.
I think that I'll take the "Mobil One" advice - never thought of those synthetics; I'm going to phone Amzoil, though, whose factory is just a few miles away from me in Superior WI. to see if they have an equivalent.
Regards from the Great White North [rural outskirts of Duluth MN], JLB
p. s., -22 deg. F yesterday & now up to a balmy +18!!! In the spring, when it's up to +35 & sunny: That's T-shirt weather around here.
