Bendtsen/Speed Gems Buying Out Wilcap Adapters
http://forums.y-blocksforever.com/Topic159251.aspx
By Calkins - 4 Years Ago
I am doing a refresher look for a Yblock to AOD kit, hoping that something new has come up in the past few years.  I emailed Wilcap, I received a reply from Speed Gems/Bendtsen's. Wilcap is currently being bought out by Bendtsen's.  Pretty much every vendor I have found selling Yblock to AOD kits are selling the Bendtsen's kit.  So, I would assume they are going to be the only source to mate a modern Ford automatic transmission to a Ford Y Block (other than Flat-O Product's C4 bellhousing).
https://transmissionadapters.com/products/ford-y-block-to-ford-aod
http://forums.y-blocksforever.com/uploads/images/d9200bfc-bc12-446c-b55d-c940.png
By PF Arcand - 4 Years Ago
Just info but you could contact the  following outfit. He's been doing trans conversions for some years, apparently specilizing in Y-Blocks.  Bristol services / Gary Croan in Costa Mesa CA  @ garycroan@gmail.com or 949 -722- 1122 ... Note;  He also advertises regularly in Y-Block Magazine looking for 58-64 Flex plates, new or good used Ring Gears & auto trans Bellhousings..
PF Arcand (12/3/2021)
Thanks, I will do that.  I had seen that name in other threads, but was unable to find any other information about them on the web.
