By 55vickey - 17 Years Ago
I've got a 55 vickey, 272, large valves and presently I've got a 600 Holley on it. I'm thinking of 3 deuces for my winter project. I've got an Offenhauser intake and just wondering if there are any prefered carbs to run on it. Thanx, Gary
By 55Birdman - 17 Years Ago
I have Holey 94s, there are strombergs that are good. And for 500 bucks each you can get the new Bary Grant 2bbl .
By Johnson Rod - 17 Years Ago
All the Carbs that 55Birdman names are good. Good used Strombergs are pretty rare and expensive. Most parts are available for rebuilding them. They are now making new Stromberg 97's http://www.stromberg-97.com/index.htm if it is the traditional look you want. (that's what I perfer).
Right now there is a trio of Barry Grant98's for $1200.00 on EBay http://cgi.ebay.com/ebaymotors/NEW-BARRY-GRANT-DEMON-98-PACKAGE-3-CARB-COMBO-DEAL-WOW_W0QQcmdZViewItemQQcategoryZ33550QQihZ019QQitemZ290257585228QQrdZ1QQsspagenameZWDVW.
One thing I did want to mention though is that the Offy manifold is not the best flowing 3x2 manifold for the Y-Block if you looking for top perforance.
Johnson rod is correct about the manifold. Try to find an edlebrock manifold #553 or 573. Those are the best. Check with Charlie Price in Fla. at vintage speed.com He is slow to respond but he has what you need. Buy the carbs on ebay will be cheaper but may be hard to find 3 good ones.
Performance isn't really an issue. I had deuces on a 55 back in 63, mostly just a nostalgic look. Reliving my youth.....if I remember correctly. Gary
It has been so long I cant remember my youth.  I am starting a rebuild on my car, these should look a lot better then. I like the nostalgia look too. Get what looks good!! Earl in NC
By PF Arcand - 17 Years Ago
What Johnson Rod & 55 birdman are saying is worth noting about the Offy intake. An old magazine dyno test & a dissecting of the manifold, reported much later in YBM, both confirm that while Offenhauser is a storied name in racing, there intake for the Y-Block was a Dog! If your 4 Barrel setup runs well now, you will likely be disappointed in the Offy setup.
By Pitewagon - 17 Years Ago
After driving since May with demon 98`s on my wagon,this is what i think of them. Easy to adjust,starts fine,1 pump on pedal and starts,leak free.same spares as "ordinary BG and Holley carbs" Bolting them on is a little tricky ,they`r"fatter" than 94`s,so its a tight fit,when swapping jets carb nr 2 and 3 need to come of. I´m happy with them so far
I have a 573 intake and 3 carbs for sale .
By ALANB - 17 Years Ago
(94's are easy to find .... the most reliable ( In my shop )and Simpelist is the Ford made flat top 4-Barrel ... I have a selection of Jets for the Stromburg's , "dating myself now" I'm looking for , to buy , (You old-timers) A Snap On Distributer machine ... some times found in schools , they were the ultiment in setting duel points Had two sets of lights , blue and red for each point !!! ..... ALAN B .
Bird man ; You have neglected to give a price and kind of Carbureters ? ... Read my post that follows please on the 15 th. Thankyou .... ALAN B .
Sorry they got sold a week or 2 ago.
By Fifty6Vicky - 16 Years Ago
What is the difference in the 94s and the 2110s? I've just acquired a set of the 2110s for a 3-2 setup on my y-block. I'm now running 94s on an Edelbrock manifold and I'm told I should be looking for better performance from the 2110s.
