Can't Find Voltage Regulator
http://forums.y-blocksforever.com/Topic159037.aspx
By Jack Groat - 4 Years Ago
We're hooking up all the wires, tubes, linkage, etc. on my '56 Crown Vic after the engine swap.  The generator has 3 wires and we didn't label them.  By referring to schematics, diagrams, etc we think we have it figured it out.  I told my son to confirm the (F) wire by checking the continuity to the center connector on the voltage regulator.  After explaining what one looks like and finding a picture, he said he could not find it.  Neither can I.
So my question is:  Where in hell is the voltage regulator on a '56.
Can't I come up with some strange questions?
By darrell - 4 Years Ago
just follow the generator wires.
Tracing the wires is kinda hard to do.  I suppose we could do it if we really needed to know.  We really don't need to know..  I'm just curious.
I was hoping somebody would remember changing one.
By Dobie - 4 Years Ago
Prolly no help, but the regulator on my '55 Merc was mounted on the inside of the radiator core support, driver's side.
By carl - 4 Years Ago
Jack the voltage regulator is mounted on the drivers side radiator deflector, inside  Carl
The 56 regulator in on the left fender well.
If you have the original wires the the small wire that’s black with a white tracer is the “F“field the one in the center.
The large yellow with the black tracer is the “A”armature on the regulator the one on the left.
The small red with the black tracer is the ground and is attached to one of the screws that holds the regulator to the fender.
All can identified with a multi meter and removing them from the regulator one at a time.
The large yellow wire “Bat” comes from the interior of the car from the light switch.
By Lord Gaga - 4 Years Ago
Jack Groat (11/12/2021)
Use an ohm meter or continuity tester!
Have you looked in the trunk?
By KULTULZ - 4 Years Ago
Now that was funny. I don't care who are ... BigGrin
Now do you use a multi-meter to find the VR or analyze the charging system?
OK, I found the regulator.  Driver's side on radiator support.  I need to explain that I am handicapped and the car is on jack stands, and I was peering over the front and could not see the engine side of the radiator support..  Sorry for starting a dumb conversation.
HOWEVER:  I now know for sure which are the field and armature wires, but back to confusion as to which are the armature and field posts on the generator.  I found an old illustration, but now I found another and they disagree.
Addendum:  Took a picture of the posts with a cell phone and can see a label of (F) and (A).  They are now all connected.
Thanks guys..  sorry I wasted your time with this dumb post..
The armature "A" terminal on the generator is the larger of the 3 and is located on the back end plate.  The field "F" terminal is on the side of the generator and is the insulated stud with an insulator bushing at it's base.  The other terminal on the side is ground "G" with no insulator.   The terminals on the side are usually identified with their respective letter stamped next to the stud.    Also, I sent you a PM........
Pinch ... ouch ...
There is no dumb question or conversation (other than my asking my thumbscrew to marry me).
If you need/want to know something you are not sure of, ask. That is why the board is here,
By rladams65 - 4 Years Ago
62 mecury is on the driver's side (left) radiator support ... about the size of half a SPAM can with a bunch of wires on a screw block
