Pumpkin Run in Clermont County, Ohio
http://forums.y-blocksforever.com/Topic158498.aspx
Is anyone going to the Pumpkin Run in Clermont County this weekend? I am thinking I will be able to stop by on Saturday. I have an intake manifold gasket that has given me a noticeable vacuum leak at the runner that feeds cylinder #2 - so much so my vac readings went down from 20 to 15 w00t. Hopefully I can get that repaired after hours over the next two days.
Link: https://pumpkinrunnationals.com
EDIT: it was actually cylinder number 1...
http://forums.y-blocksforever.com/uploads/images/43ce943d-f1fd-45a3-b373-271.jpeg
When I pulled the intake the gasket for the #1 intake runner was already in this shape, but #3 let go rather quickly with a clean break as well. I used white lithium grease so nothing "stuck" to the manifold or the heads for that matter. Not sure what gives on all this. The gaskets were installed about 6 and a half years ago and nothing has been touched since then.
http://forums.y-blocksforever.com/uploads/images/cedb2b8a-b335-49d7-a62e-3e3.jpeg
I installed new gaskets last night and will be on the road first thing tomorrow morning headed to the Clermont County Fairgrounds in Owensville, Ohio. I plan to stay until about 5 pm or so - look me up if any of you can make it.
http://forums.y-blocksforever.com/uploads/images/35ef36f0-563e-4477-bdb6-76d.jpeg
I had to register late - so I am car #2363, yep - that many cars at the show.
http://forums.y-blocksforever.com/uploads/images/09d3b845-334a-4b01-985f-3fe.jpeg
