By bergmanj - 5 Years Ago
Folks, Just "picked-up" a nice '55 Crown and am looking for current information on what shocks to use for best fit -- front and rear, travel (enough "drop" to allow for rear tire changes); and, with "helper springs" for the rear. Manufacturer and part numbers would be appreciated. Rear end is low with Continental kit on it & cannot afford to do anything with rear leafs at this time. Going-in for an alignment in two weeks and would like to install new shocks at the same time. Regards, JLB
By Lou - 5 Years Ago
I would not replace the shocks until i was ready to replace the springs and do front and rear springs. Replace the rear springs with 6 or 7 leaf springs. Do a Google search for "overload shocks", found my local parts store has them.
Thanks for the reply, Lou.
What you suggest is the "right-thing" to do; however, funds are simply not available to do that now; so, I still need information on shocks. No one else??
Regards, JLB
By 1/8cavman - 5 Years Ago
You are lucky to find a nice 55 Crown that is affordable. I would not waste money on an alignment at this point. A-arm bushings, idler arm, tie rod ends, should be closely checked and replaced, if needed. KYB gas-a-just shocks are a good choice for shocks and are on sale quite often on Rock Auto. The ball joints are almost always ok, if they have been greased as they should. As far as the rear springs, don't flip the shackles to raise it up. Replace the front and rear bushings, they are almost always worn out. Look for some station wagon rear springs or try to find some leaf springs that are very similar and cut the spring eyes off the main leaf and add to your spring pack. Also when you have the spring pack apart grease the pads on the end off the leaves to get a smoother ride. This comes from 25 years of suspension and alignment on all kinds and off-road vehicles. Ist Cav Man
By miker - 5 Years Ago
How about looking for a set of old fashioned air shocks? I’ve got a buddy with a 56 scrubby Nomad that has an old but good set on the back. When he loads it up, he adds air to bring it level. Doesn’t make much difference in the ride, just works. No compressor on board, he just airs them together thru a fitting in back. You could use the trunk, or hide it under the Connie kit.
You might need to find a good counter guy, or get into the online catalogs to check dimensions (extended/compressed) and car weight, but I’ll bet they’re out there in Monroe or Gabriel (or whoever owns them now). Might even try the Ford barn and see if the Courier guys have a lead.
Those would let you level the car now, and would possibly replace the helper springs when you replace the main springs someday. There weren’t many Connie kits on the full size cars, so likely the replacement springs will either need help, or have to be custom made for the weight. Wagon springs maybe?
Thanks, folks, I'm still looking; does anybody have the compressed/extended length specs (especially extended!)? I know that this was discussed here quite some time ago; but, I wasn't able to find through "search" function. Many places sell shocks (supposedly) for this car; but, I also know that some folks on here and elsewhere have had problems with the extended length being too short to allow tire changes without letting air out of the rear tires - I'm trying to totally avoid that "pain". Regards, JLB
By Ted - 5 Years Ago
See if one of these links to past threads helps. http://forums.y-blocksforever.com/FindPost74608.aspx http://forums.y-blocksforever.com/FindPost74631.aspx
Ted, Thanks; It looks like good information - I'll check it out further. One of the threads referred that Gabriels had 3" more travel than KB's; I'll look at their respective spec's. If anyone else has specific experience, I'd like to hear bout it too. Regards, JLB
I have the stock shocks on my 56 and it is not lowered. My rims are 15-6” instead of the original 5” width with 215-75 series tires. The original bumper jack works fine. Since your only jacking up one side it comes down at an angle and the tire is tight but comes out. The stock 5” wide spare goes in easy. I do use a small scissor jack under the axle to just barely raise the wheel off the ground for protection. I have also left on the bumper guards so the bumper jack will not slip. I also use towels to protect the chrome.
I will say if my car is on a rack at a shop I request to be there when it comes down as the shackles will flip and are a real pain to get back one at a time with a long pry bar and 2 jacks…
By MoonShadow - 5 Years Ago
I have those Gabriels on my lowered 56 and they helped a lot. With 8" rims and stock tires they change easily.
Thanks, again, According to Gabriel, the G63398 shocks have been discontinued. I also tried several sources on "The Web" which all said either unavailable or discontinued. Anything else? Regards, JLB
Check your local parts store for a cross reference. http://www.kakapart.com/oem/partscrossinterchange/autozone-g63398.html
By PF Arcand - 5 Years Ago
Yes,this problem has come up before.. apparently a couple of manufacturers list shocks for mid 50's Fords..that are too short. On my 57 car the rears are Gabrials & are marginal for clearence. As I recall, I added a one or two xtra shock washers at the bottom, there was enough thread, & can get by.. In my opinion, Contlnental kits can be more of a pain than they're worth...
P.F, "Contlnental kits can be more of a pain than they're worth... " My 1st experience ... if proves too much, I can always remove. I'll have to see how it goes. Still looking for specific brand & model information for replacement shocks. Thanks. JLB
