By silent rick - 4 Years Ago
edelbrock 257 with one inch spacers and adapters to run edelbrock carbs or AFB's SOLD
edelbrock fm255 with teapots and progressive linkage. SOLD
polished offenhauser 6x2 intake. $800.00 plus shipping
weiand 3x2. this had some corrosion issues. i had a friend heli-arc the one port. needs to be ground or filed flush. $200.00 plus shipping.
By Fairlane57 - 4 Years Ago
Hi Fella am intrested in the 257 you have for sale, would you be intrested in getting me a shipping price to the UK for it ?. i have a crack in my existing manifold and although plugged up at the moment i know im gonna need a replacement some time soon. regards Martyn.
sure, what city and postal code?
Hi mate ,sorry for late reply but cant respond on my phone for some reason ! so i have to use my lap top from home. My address is . M Taylor, 21 Chanctonbury Close, Rustington, Littlehampton, West Sussex, BN16 2JB. UK. Im guessing that postage and taxes will make this an expensive exercise but lets see. Best regards Martyn.
By PF Arcand - 4 Years Ago
Martyn: for what it's worth, those aluminum castings can be Arc welded... P.S.- looked back at your post & realized you didn't say what your intake was? Cast iron or aluminum?.
Hi mate, yeah its the originol cast 4 barrel manifold, it leaks from a crack by the front [Your nearside] right hand bolt. unfortunatley Y block stuff over here is rarer than 'unobtanium' you wont even find a nut and bolt for em on ebay uk. To be honest i dont need a 2 or 3 carb set up, but if its gonna cost an arm and a leg to get stuff shipped over whatever type it may be, i may as well look into all avenues and costings .I should of said the motor is a 292 in a 57 Fairlane country sedan, its unusual in that its a right hand drive as it came from Ford South Africa. Regards Martyn.
Martyn: An experienced Welder & Brazer can probably fix your casting.. Done right & installed carefully it should work fine.. The main thing with brazing cast is to align the pieces carefully & to avoid the casting being chilled when cooling.. Wrap or submerge the job in a welders blanket or other suitible covering & cool it "slow"..
bump to the top with lower prices
