By ogasman - 5 Years Ago
I have a 56 292 that I am building. Had the block tanked, bored, new cam bearings. Went to put the new Isky cam in, no bueno. It fit the first 4 cam bearing a little snug. When it started into the 5th it bound up hard. The cam looked good when I cut the oil groove deeper, but I did not put a mic on it. I still have the old cam. It had quite a few miles on it, and a couple flat lobes. I can get it into all 5 bearings, but it is a lot tighter than I would run it... Cannot turn it over by hand. I have seen where people cut a cross grove into the old cams bearing journals, and use it as a reamer to open up the new bearings. Is this a good idea? Anyone know something better to do?
By Cliff - 5 Years Ago
Run a little scotch bright around all the bearings (softy) sometimes 2000 grit sand paper is necessary, be careful when the cam fits clean the crap out of it, this is normal work most machine will do this and not tell you what they did.
By blocky - 5 Years Ago
yes good old scotchbrite.make sure the cam spins
By Florida_Phil - 5 Years Ago
I had this problem a number of years ago on a 312 build. I never had it with FEs or small blocks. I understand it's a common problem. I had to scrape the bearings to get the cam to turn freely. I took me some time, but I finally got it done. It made me somewhat nervous as it seemed like a Neanderthal fix. Looking back, I probably should have taken the block back to the machinist. Must have been OK as I ran the engine for years without a problem.
By darrell - 5 Years Ago
ive installed cams with slight drag after putting in new bearings and didnt have a problem.as long as i can turn it by hand.
By Joe-JDC - 5 Years Ago
I would try the old camshaft and see if it will slide in. If it will, then measure the journals on the new one and compare. May need to remove and replace that last bearing. Joe-JDC
I think I fixed it.
The old cam would slide in, but it had a little drag on all the bearings as I spun it when I put it in. It seemed like the 4th and 5th bearings were the worse. It was pretty hard to turn when all the way in. Could not turn it by hand. The new cam would make it to the 4th bearing with a good amount of drag. It would not go into the last bearing. I thought about fitting it by hand, but I could see more than one shiny/high spots a few places on different bearings. I put two narrow (less the 1/16 inch) angled grooves on opposite sides of each journal of the old cam,. Put some grease in the grooves, and put it back in the motor. I slid it straight into the motor, and then started to turn it over when it was all the way in. I could feel it start to get easier as I spun it. I worked it in and out a little bit once it turned over easily. I got out a decent amount of material from each bearing journal, more on the 4th and 5th bearings. I tried the new cam, now it fits. It still has a bit more drag that I would like, but it will probably be alright. The finish on the bearings was not perfect, but not too bad.
By Richard - 5 Years Ago
Check to see if the cam is slightly bent. This happens more then you think. A good machinist can Chuck it up in his lath and check with an indicator and can straighten it for you.
By 55blacktie - 5 Years Ago
Cam-bore alignment could be the problem.
By Ted - 5 Years Ago
While the 312 engines are notorious for the camshafts not fitting cleanly into freshly installed cam bearings, that’s typically attributed to the cam holes on the 312’s being machined from each end with those machining operations meeting somewhere in the middle. As a result, 312’s are noted for crooked cam tunnels and the subsequent failure for freshly installed ‘stock’ cam bearings to allow the camshaft to simply slide in place. The factory got around that by having a 0.015” undersize cam bearing and then honing those factory installed bearings to the desired fit. Those bearings were available for awhile as part numbers B4C-6261-B (frnt), EBY-6263-C (X3), and B6A-6262-B (cntr) to make up a full set. While that is a 312 nuance, the 272/292 engines were machined on a different machining line and the cam holes are machined in a single operation from one end to the other. As a result, the 272/292 engines do not have the same camshaft fitment issues as the 312’s. Like all other engines out there, the 272/292 engines are not immune to other fitment issues. When a 272/292 has a camshaft fitment issue, the cam hole or holes being machined on the small side and/or the cam bearings being slightly thicker than required are suspect areas to examine. It’s rare for a camshaft journal to be so far oversize that it will cause a fitment issue when everything else checks out okay. When the specs stack up with a slightly smaller hole in conjunction with a slightly thicker cam bearing and/or a journal size that’s only ½ thousandths larger, then fitment issues can come to the forefront. This can happen even when all the offending parts are within the variability listed in the specifications. Bent camshafts are always a possibility but they are rare. Besides a cam bearing being installed crooked, cocked, and/or damaged when installing them, I find cam holes in the block being machined undersize being the root cause much of the time. If you deal with BBC engines very much, undersize cam holes seem to be a way of life with those engines. On those, I’ll simply mic the holes before installing the bearings and address undersized holes before attempting to install the cam bearings. What Paul did with an old camshaft with grooved journals to open up the bearing clearance is an accepted method for fixing that problem. Scotch brite works too. On undersized holes, grinding the outside of the bearing appropriately in a crankshaft grinder is also an accepted fix. Taking the block back to a machine shop to correct the problem will simply have that shop doing ‘old’ grooved camshaft fix or using a bearing knife to carve some additional clearance in the offending bearing(s). A good number of machine shops will already have those grooved camshafts sitting on a shelf for the various engines. For myself, I will generally leave the rear cam plug out of the block until I have test fit the camshaft in the block and insure that it turns freely. If the camshaft has difficulty turning or installing all the way in, then I’ll install the camshaft from the rear and determine which cam bearing in particular might be the problem. Installing the camshaft from the rear may indicate an issue with one of the center cam bearings instead of assuming it’s just a rear bearing problem if only installing the camshaft from the front. From there the appropriate fix is applied. This is assuming the camshaft is indeed straight but as I previously mentioned, that’s a rare occurrence but easily verified by just measuring the camshaft while rotating it in a pair of V blocks.
I don't know about bending a cam, but I snapped a 235 inline six cam many years ago, threw a rod, too.
55blacktie (2/17/2021)
I don't know about bending a cam, but I snapped a 235 inline six cam many years ago, threw a rod, too. I broke a cam in a 292 once. Braking stuff was not that unusual for me back then. I drove like an idiot. I had no money. I didn't know what I was doing. Thankfully, I somehow managed to fix the first two.
By Lord Gaga - 5 Years Ago
Ted, Would grooves parallel with the cam work as well as angled ones? Would be a lot easier to do!
I had that issue with a 292 recent ly. used a cam core with a grov in the bearing aria which makes the 1 grove a cuter depending on the tight cam bering is where you make the cuter. may sound a bit crude but small amount of clean up, then when cam car is back in place take a block of wood and give the cam a smack. I my case the new cam went in and turned with ease. learned this trick from a local machine shop
When working with machined surfaces you should never wack anything.
Is there a difference in "whack" and "smack"? You are supposed to smack/whack the crankshaft flange to check for main bearing clearance on the thrust bearing surfaces. I know some folks use a long screwdriver to move the crankshaft back and forth, but originally we were taught to smack the crankshaft flange with a rubber mallet. Never say never. LOL. Joe-JDC
Lord Gaga (2/18/2021)
Ted, Would grooves parallel with the cam work as well as angled ones? Would be a lot easier to do! Using a badly worn or discarded camshaft, I prefer a single diagonal cut on the rear journal. That will provide a longer cutting surface as well as being ‘self cleaning’ as long as that diagonal is cut in the direction in relation to the direction that the ‘modified’ camshaft is being turned within the bearings. I typically only make a groove in the rear journal and that groove is made at an angle rather than a straight down cut so it has the appropriate sharp cutting edge on only one side of the groove. Never make these modifications to the camshaft that is going to be run within an engine. I trust that made sense.
Edited after posting for clarity. Ted.
Ted, I take it that the angle groove left in the cam journal has no effect when the engine is running and all the bearings have sufficient clearance to perform as designed.
The groove is only cut in an old camshaft for a tool to make installing the new camshaft easier. Not in a running camshaft. Joe-JDC
Joe, what if the original fits properly and the new one doesn’t which was the original question. Very early in my training and watch my dad with a bearing scraper I learned how to fit and scrape a Babbitt style bearings. Thats why grooving a journal was so interesting.
Thanks to Joe for chiming in and setting the record straight. Never modify the journals on a camshaft with ‘cutting’ grooves that is intended to be run within an engine. In the event an original camshaft fits freely into the cam bearings but a replacement camshaft does not, the problem is likely in the replacement camshaft. This is assuming that a set of undersize cam bearings are not in the block and the original camshaft had had its journals reground accordingly. That particular scenario was a common practice back in the day but not so much today. Back to the replacement camshaft not fitting, then simply mic the journals and compare those sizes to the original. Then check the replacement camshaft for being bent. That can be performed in a pair of V blocks and a dial indicator. My bad for not clarifying that ‘cross’ grooving a camshaft is only performed on old or throwaway camshafts for the purpose of removing babbit from cam bearings that are too tight for the camshaft that’s being used to freely turn. Under no circumstances should the camshaft that’s being installed within engine for final use have those ‘crosscut’ grooves in them. Not only will the existence of those grooves in a running camshaft continue to carve out bearing material, they are an additional path for oil pressure between the bearing and journal to be relieved. But bearing material removal will more than offset those other problems very quickly. Treat camshaft journals just like crankshaft journals. On a different but related topic, several years ago I had tried to get CWC to make one hundred cam blanks with no oil groove on the center journal. By doing this, the center camshaft bearing would not wear out as quickly by permitting a dynamic oil wave to be present as is on the other four cam bearings. In a center grooved camshaft application, the center cam bearing in a Y always exhibits more wear than the other four. Cross drilled camshafts on the other hand do not exhibit as much wear issue on that same bearing location. The CWC order was just too small and there was no interest on their end in doing that. I have welded up that oil groove on the center journal and reground that journal to spec in a crankshaft grinder and those camshafts are still in service today. Until one of those engines is torn down for inspection, I can only assume that the bearing wear on that center journal has indeed been minimized to the same level as the other four. For the non-grooved center camshafts, the oil for the top end of the engine comes from a machined groove in the block behind the cam bearing much like is being done on the FE engines.
ted what would happen if you just turned the cam bearing until the holes to the heads were blocked of.drilled a new hole to feed the bearing would the groove still wear the bearing.
Excuse the lengthy post again as there’s a lot of information to be shared here. Darrell. As you point out, it is the groove in the center camshaft journal that’s the root of the problem and not the other two holes in the bearing that permit oil to be fed to the top of the engine. Even if the two additional holes in the bearing were not there, that groove is allowing some of the oil pressure to bleed off at the top of the journal and is preventing a proper oil dynamic wave from being created at the bottom of the journal. The wear characteristics at the center cam bearing with a cross drilled camshaft are much more reduced than what is seen with the grooved camshaft journal. The engineers at Ford must have wrestled with this as the 1954 and 1955 engines used cross drilled center journal camshafts and went to the grooved camshafts in 1956. Comes 1963, the cross drilled camshafts are back for the Ford pickups and trucks. If it's any consolation to the cross-drilled camshaft design, I've pulled apart several of those engines that were very high mileage with some being over 300K miles and they were still oiling the top ends of the engine just fine. Good oil and regular changes go a long way in keeping the wear to a minimum on these engines. Complicating that cam bearing wear issue is the latest crop of cam bearings. They are softer than the originals and just wear or ‘seat in’ much more quickly. The Engine Tech CC-508 bearings made in South America are a harder material than found in the Sealed Power and Durabond cam bearings for the Y. If I know I’m going to have a cam bearing issue such as with a 312 with crooked cam tunnels, then the Sealed Power or Durabond bearings are definitely easier to ‘carve’ on in which to get the camshaft to freely turn. For the 272 and 292 engines that are not going to present an issue, then the Engine Tech cam bearings are the bearings of choice. I do have a machined bar here to check for cam tunnel alignment. That bar when inserted from each end of the engine will point to the exact areas of the cam tunnel that are going to give the most trouble. With that information, the cam bearings can be altered appropriately before they are installed in the engine thus speeding up that process considerably. I have had some 312 engines so bad on that alignment that I simply re-bored the cam tunnel hole to the 1954 hole size and then made new cam bearings from scratch using bearing bronze. On those bearings, I only put in one hole for the cam journal with the oil supply to the top end being supplied by a machined groove in the center cam hole. The 1954 cam bearing hole size is used so that the 1954 rear cam plug can be used. For the 427 FE side oiler engines, Ford went to a grooved camshaft to provide oil to the top end. On those engines it was the #2 and #4 journals. This was done to reduce the oil flow to the top end and thus supply more oil to the bottom end. Unfortunately this brought up the same issue of the cam bearing material pressing into the camshaft grooves in the #2 and #4 journals and shutting off all the oil supply to the top end. When a roller camshaft is used with the much higher valve spring pressures, cam bearing issues came to the forefront almost immediately. On a flat tappet camshaft, it just took a little bit longer. On those 427 side oiler engines, I simply machine a groove behind the cam bearing and use a conventional (non-side oiler set) cam bearing set to eliminate that issue. If needing to restrict the oil to the top end, a restrictor at the top of the head under the rocker arm stand fixes that. In a perfect world, the oil supply to the camshaft journals would be located at the four or five o’clock position when observing this from the front of the engine rather than at the six o’clock position that those bearings are normally installed at. Ford actually started doing that 4:30 o’clock positioning in 1972 with the FE engines after fourteen years of installing those bearings simply at the six o’clock position or aligned at the main bearing feed hole.
Excellent information Ted and very much appreciated. This is better than sitting by the fire on a cold winter/s night reading your favorite technical publication. ......
By Dobie - 5 Years Ago
Ted, I looked at EngineTech's website and found the CC 508 bearings are listed for '56 and '57 engines, no other years listed. Are there differences between those 2 years and earlier/later engines? I wouldn't think so, but Ford has been known to do strange things on a seemingly random basis. I have a '55 Merc 292 that has the known oiling problem to the passenger side rockers. I've had the rocker assembly off and squirted carb cleaner down the feed hole in the head. The carb cleaner seemed to go through the passage with little resistance. I also blew shop air through the hole, again with little resistance yet the oiling issue continues. Would this indicate a spun bearing or a clogged groove? I don't know if the cam is grooved or cross drilled. Does anyone make a cross drilled cam for Y-blocks anymore since it appears cross drilled is the better idea?
I have a rebuilt set of G heads I'll be installing soon and while the heads are off I'm going to run the oil pump with a drill to see what comes out of the feed holes in the block. Right now the driver's side oils just fine but he passenger side is nearly dry in comparison.
years ago almost everyone said the grooved cam was the way to go.but i used to think i never saw an overhead oiling kit on a 55.i suppose there was a few but dam few.ford took a step backwards as far as i can see.
By slumlord444 - 5 Years Ago
I used the super fine sandpaper trick on mine many years back. Worked fine. Still working with the second cam.
Dobie. To date, the only spun cam bearing I’ve ever seen in a Y was one of my brass ones where I did not have enough oil clearance built into it. That engine was in my race car and learned quite quickly that brass likes additional oil clearance versus what is used for a babbitt constructed bearing. If your engine has been previously rebuilt and the cam bearings were replaced, then there’s always the chance that grooved camshaft bearings were installed and those do not work well with cross-drilled camshafts. The Engine Tech CC-508 cam bearings do fit all years of Y using the grooved center journal camshaft. They do not work with cross drilled camshafts without modifying them. Durabond offers two different cam bearing sets with one being for grooved journals and the other for cross-drilled journals. I’ve come across a number of Ford Y’s that had been rebuilt at least once in their lifetime that had evidence of having overhead oilers before I purchased them as core engines. In tearing these engines down, some had the center cam bearing installed incorrectly by the rebuilder where only two of the holes aligned and the third did not. From the git go, these engines failed to provide oil to one bank or the other. All three holes must be aligned. Overhead oilers were obviously a cheaper fix than tearing the engine back down. Other engines simply had the softer cam bearings and the center journal groove was simply pushed into the bearing material thus shutting off the oil flow to the top. For whatever reason, when there is an oiling issue at the rockers, it’s the right bank that experiences a reduction in oil flow first. Sludge was the largest single issue with top end oiling back in the day. At a shop I worked at during the early seventies, one of the mechanics had fabbed up a flat piece of steel with a zerk fitting that would bolt up to the head with the rockers off. By using a grease gun and and pumping white lithium grease into that oil hole, any debris or sludge was pushed back into the engine thus clearing up the feed for the oil. That approached worked well as the grease had a low melting point and easily dissolved when the engine warmed up.
Thanks, Ted. I'll have a better idea what's going on when I get the G heads back from the machinist. With the heads off I'll run the oil pump with a drill to see how much oil comes out of the feed holes. If it's pretty much equal on both banks I'll assume there's a blockage in the head or rocker shaft although when I had the rocker assembly off I ran some solvent through the shaft as best I could without taking it completely apart. Nothing of note came out of it. I have a set of rebuilt rocker assemblies that will go on the G heads anyway. If oil flow is still restricted the engine is going to the machine shop for a refresh.
