Any Early Bird seat upholstery experts?
http://forums.y-blocksforever.com/Topic154981.aspx
By yblock57 - 5 Years Ago
Kicking around the idea of installing the pre-made seat cover on my '57 bird. I've done a few seats in 80's mustangs with decent results and have built up the courage to give this a shot.
Anyone on here done this on an early bird? Any tips/tricks? I have a decent set of hog-ring pliers and a heat gun.
Would likely buy everything from CASCO. The works — foam, backer, burlap and cover. Noticed they sell a seat recovering DVD. Anyone seen this? Think it's worth a try?
Thanks in advance.
http://forums.y-blocksforever.com/uploads/images/a729e141-590b-44d8-8b01-6646.jpg
By 55blacktie - 5 Years Ago
Someone recently posted on another forum, regarding his T-bird's seat height being considerably higher after being reupholstered; his head is now above the top of the windshield. In his case, I don't think the new foam was trimmed before installing the upholstery. Over the years, foam will compress and deteriorate, thereby reducing the seat height, so you may see a considerable before/after seat height difference. Considering the cost of materials, I would leave the job to a professional who has done T-birds.
I have the DVD, well worth the cost.
By DANIEL TINDER - 5 Years Ago
55blacktie (2/12/2021)
I bought a leather set for my ‘55 from Larry’s.  Pulled the seats myself and took them (new foam) to a local
/rural auto upholsterer.  Turned out ok, but he said it was the hardest job he ever tackled!
55blacktie — Yeah, I had heard a few folks talking about foam height/thickness issues. Being 6'2" and needing all the room I can get between the wheel and the bottom cushion, I'll stick with my foam. It's intact and seems ok. Guess I'll find out when the cover comes off.
John — Thanks. I'll order that DVD. Appreciate the recommendation.
Daniel — what did you pay for the leather cover if you don't mind me asking?
By 1/8cavman - 5 Years Ago
 I would buy the video first, then decide on doing the job. A leather cover may make the job harder. Also 57's came with or without the emboss emblem on the back rest, depending on the manufacture date. The new dense foam "looks" great, but will raise the seating height. I have switched the drivers and passenger springs because the passenger side were used less. If you have a power seat look at the seat rails for excessive wear and good operation. Does anyone have any experience repairing the "waffer" part of the lower power seat motor of the Dial -o-matic seat on a 57 Bird?
By NoShortcuts - 5 Years Ago
1/8cavman.  I'd highly recommend that you contact Felix NatoliFelix has worked on numerous '57 'Bird DialoMatic set-ups in the last two years and has a complete working unit mounted on a display board to guide him in working on others that he assembles or trouble shoots.  Speak-up if you call him on the phone.  He's no kid.  He bought his '55 'Bird in 1957 after getting out of the Army!  He's presently finishing-up on the restoration of his D code '57 'Bird that he's installed a complete 'Bird F code set-up in include the 'F' automatic transmission.  He's installed new seat covers and is presently working on installing the '57 'Bird's replacement convertible top fabric and weather stripping.
Feel free to tell him I gave you the info.  Felix is the older brother I never had!  He's located South of Rochester in New York state.
Felix Natoli  -  (585) 237-2455 (home phone)
email - natolibird@aol.com
Hope this helps!  Smile
1/8cavman (2/12/2021)
Yes sir, I'd planned on purchasing the DVD first. Hopefully it doesn't scare me from the job.
The car is a manual seat. I believe the original foam is serviceable. Guess I'll find out if/when I get into it. Nothing feels saggy or broken. Cover is just old and started splitting on the seams from use. Definitely don't want something that will make me sit higher and close the gap between the steering wheel and bottom cushion. I'm 6'2" so that's already pushing it — especially with the top on.
Car is a late production (July '57) but I want to keep the embossment that the current cover has. Not worried about it being 100% correct.
By miker - 5 Years Ago
When I had my 55 done years ago, I used the leather seat cover from Larry's Thunderbird, along with a whole interior kit. The local upholstery guy did the seat bottom and back first, then went thru the rest of the interior, carpet, etc. I used new foam. He stretched the seat every morning (in a heated shop). He said if you had time to do that it was the best way to get a proper fit, and worth the money for him to do it 3 or 4 times. It still looks good for fit 18 years later so he must have done something right.
miker (2/12/2021)
Sounds like he really knew the tricks to a great job. Hard to beat fresh leather.
Don’t have a detailed invoice for the leather kit (purchased entire new interior upholstery/carpet/hardware/etc. thru a secondary outlet 13 yrs. ago), but I do remember it wasn’t cheap! I sprung for leather though because my car had new vinyl seat covers when I bought it, and it only took 10 years to wear them out.
Orig. foam was really shot, and the new seats not only raised driving height slightly, but especially also put me in a decidedly more upright posture.
Daniel —
Sounds like you made a good choice with the leather & foam. I'm a little worried new foam would push me too high and make driving more difficult. 6'2" isn't the best fit in an early bird. Hopefully my original foam is reusable. Will have to dive in and find out.
By RJ Palmer - 5 Years Ago
My wife and I covered the seat in our 57 T'bird a few years ago and I think it came out fantastic! We had planned to take it to our local upholstery shop on Cape Cod , Ma but were informed that he was so busy (It's a one man operation) that it would be well into the fall before he could do our car.He said we could do it  if we did 2 things. 1-buy a pancake air compressor and its hose and staple gun (reasonably priced at Harbor Freight) , plus they always have coupons.  2- You must do it 0n a  90+ degree day after letting the covering sit in the hot sun for hours. If you dont do that you will not be able to stretch the material the required amount.We bought most of our supplies from Casco, i.e., upholstery package with tack strips , hog rings, etc.  Took our time on a very hot day in July, did the seat on the first day and the seat back on the second day. I stretched the fabric/vinyl while my wife fired the air staple gun.! The whole operation was pretty sweet and I cant overstate the importance of doing it on a VERY HOT day..  Good luck    RJ Palmer
RJ Palmer (2/16/2021)
RJ — Thank you for the tips and insight on the seat. Very helpful and obviously a summer project!
By Florida_Phil - 5 Years Ago
Anyone ever put low back bucket seats in an early TBird?
Phil, you might try contacting Gil Baumgartner, who put low-back buckets in his 57. He is in his 80s, now, retired, and did not reply to my last email. Someone told me that he might take on a job now and then, but he's pretty selective. If you reach him, I'm sure he will be happy to tell you what seats he used and how they're mounted.
By ian57tbird - 5 Years Ago
The original foam eventually turns to dust. When moving the seat back forwards and backwards, it was like yellow sand falling out of it.
 I replaced my foam and found it was much more comfortable with better lumbar support. I didn't get a sore back after driving the car like I once did.
