Synthetic oil in 9" rear end
http://forums.y-blocksforever.com/Topic154568.aspx
By slumlord444 - 5 Years Ago
It's been discussed before but I''m having trouble with the search function. Currie says don't use it. Been running it in my T Bird with no problems and planning on using it in another car. What are your thoughts?
By 55blacktie - 5 Years Ago
I have an Auburn limited-slip in my 55 Dana 44. It came with an additive, but I was told not to use synthetic. I don't know that it would be a concern with an open differential. there are synthetics that are safe for hypoid and non-hypoid.
By Ted - 5 Years Ago
My issue with synthetic oil in rear differentials are oil leaks at the pinion seals.  While not every rear will leak oil with synthetic oil, I’ve had enough of them to do so that I’ll not use synthetic oil there.  In those instances where the rears leaked using synthetic oil, switching back to conventional oil stopped the leaks.  Only after replacing several pinion seals in rears that leaked synthetic oil was it finally figured out that the synthetic oil was the problem and not the pinion seals themselves.
By 57RancheroJim - 5 Years Ago
I'm thinking they must have newer seal materials that can handle synthetic. The old seals don't like it. When I took my 9" in to have new gears, bearings etc I was told there was no problem using it. This was by Hoopers who build tons of rear ends. So this was the first time I used synthetic and I'm reaching the 10,000 mile mark with no leaks.
One of the reasons for my restoring my 55 T-bird is that it leaked from every possible location-engine, transmission, rear end, and steering box. So far, I find no signs of leaking from the rear end, but I'm still working on the restoration. What advantage to you expect to get from using synthetic gear oil, and how often/how hard do you intend to drive it?
57RancheroJim (1/14/2021)
My 57 is my daily driver. I've made several runs at 95mph across the desert. 95 is about my limit with 3.89 gears and OD and a small 390 cfm carb. I do lots of hiway trips running 65-75 for hundreds of miles. I only used it because I got it for free from a friend. If you have old seals I wouldn't recommend it
The differential manufacturer may specify mineral oil.  You'd have to ask them for  the precise reason why.
Non synthetic is strongly recommended by the manufacturer of the differential in my truck.  It is a geared differential rather than clutch and it apparently works best with non synthetic and without friction modifier.
Want to use synthetic because it's supposed to be better.
By KULTULZ - 5 Years Ago
We get asked this question almost every day, and the answer is straight up, you should only run 85W-140, API GL-6 rated conventional (non-synthetic) gear oil in a Currie axle assembly. You may hear about how synthetic gear oil provides reduced friction and wear; however, it may not be optimal for your setup – especially if you have a Ford 9-inch rearend. Hear us out.
SOURCE - https://www.currieenterprises.com/why-run-conventional-gear-oil
CURRIE is stating to use non-syn in their assembles only.
If using a SYN in non-CURRIE application(s), you would follow the manufacturers recommendation and/or the refiners recommendations.
