By paul2748 - 6 Years Ago
Asking for a friend. He has a 54 wagon, 292 automatic with dual exhausts. Can't reconfigure the neutral safety switch as exhaust in the way. Any solution?
I know back in the day there was an aftermarket manifold made (for Merc's I think) that would work. Very rare.
By iowa fords - 6 Years Ago
Is the neutral safety switch on the steering column?
Yes - on the steering column
Here you go! There’s an extension on my shift arm for a trans change and the right upper is a heat deflector for the master cylinder. Neutral start only....theft protection..
By patm - 6 Years Ago
These are part numbers from the ford parts books; these are listed for the 1954 ford using dual exhaust systems. The shifter arm combined with the switch tripper is AE 7302-A. The bracket which mounts the switch and stabilizes the shift tube is B9TT 7317-A. I purchased both of these from Green Sales Company in Ohio (they may have AE 7302-A). The picture posted by Dry Lakes Racer is identical to mine. I chose to use a 1958 switch (starts in park).
Pat in AZ
Thanks drylakes and patm - will give info to my friend
