Using Small Block Ford Fuel Pump
http://forums.y-blocksforever.com/Topic153801.aspx
By Jack Groat - 6 Years Ago
I have a brand new small block Ford fuel pump.  The bolt pattern is the same, gasket area is not but looks functional.  The lever is the same length but meets the cam eccentric at a slightly different angle.
The reason I like it is it is small and CHROME...
I know many have used FE pumps. After I install the AC unit I’m looking at I will no longer need a vacuum assist supply or that part of the earlier pumps. Will be interesting seeing the answer to your question.
I have used FE fuel pumps with no issues except for only getting about 5 years of service due to alcohol in our fuel.  I question the use of a small block pump and the approach angle of the operating arm. Make sure the sb pump is being operated at the stroke it's designed to run at.
By 55blacktie - 6 Years Ago
Everything I've read indicates that only the FE fuel pumps are Y-block compatible.
I used a small block pump by mistake, before I knew better.  The truck made it about as far as I would expect  with a full float bowl.  I later sold that pump on eBay and the guy who bought it said it was bad and the place I bought it from actually replaced it for him.  So not really sure if it will technically allow the engine to run or not.  Maybe the arm difference damages the pump?  The FE pump does have a correct pump arm so it is the best way to go.
By Florida_Phil - 6 Years Ago
charliemccraney (11/6/2020)
Been there done that. As others have stated, the FE pump is the one you want.
