By 55charliebird - 6 Years Ago
Do I tap into the fuel line before the mechanical fuel pump or between the fuel pump and the carburetor. Also what is the preferred way to hook it in the system. It is a 6v pump with max 4 psi pressure, as prescribed. Electrical is not my problem but I do want it to work properly without causing flow or air problems for the engine. Thanks as always. Charlie
By 55blacktie - 6 Years Ago
If you are installing an auxiliary electric fuel pump, it should be installed near the gas tank. You should use a filter between the electric fuel pump and the mechanical pump. You should also use a smaller filter between the mechanical pump and the carburetor.
close to the tank,have a switch so you can use the electric pump only after car sits for a day or longer,like previous combat yes a filter won't hurt. i have installed several on 6volt cars,2 on birds that want to stay 6volt, and has original holley garb,swell a55merk,did not use a additional filter.
By MoonShadow - 6 Years Ago
Back when I was running the McCullouch supercharger I had a problem with fuel starvation in 2nd gear. I installed an inline pump back at the tank with a switch on the dash. Even with the Holley 427 HiPo pump I couldn't get through the quarter mile without the auxiliary pump. With the 4-71 its still in place and I leave it on all the time now. Works for me.
By Vic Correnti - 6 Years Ago
My 2 cents would be to have a filter before the electric pump.
Vic, I replaced the tank when I redid the car so I put a filter after the electric pump and another bigger one after the mechanical pump up front. My old tank was full of sugar sand from sitting in El Paso for many years.
Make sure gas tank and line are clean.
Chuck, the filter before the pump protects the electric pump from tank debris.
The filter before the pump can be more of a screen, 100 micron, that prevents "big" particulates from getting through. After the pump should be the fine filter, 10 micron.
By Gene Purser - 6 Years Ago
Hi Charlie, I'm trying to work out your reasoning for a filter AFTER the pump rather than before it. Is the pump subject to emitting debris? If so, I see the logic by not placing a partial restriction before the pump. If not, why not put the filter BEFORE the pump and keep as much contaminant as possible from wearing the pump?
Gene, A filter goes before the AND after the pump. The one before filters larger debris, to protect the pump while minimizing flow loss into the pump. That one is often like a very fine screen. The one after filters out smaller particulates that can cause problems in the carburetor.
Thanks Charlie
