By wrcannon1 - 6 Years Ago
  I have: 2 ea. ECZ-Gs 1 ea. 471 See attached photo of sand blasted and maged head. Note it is a truck head with the large Exhaust valve guide 1 ea. 5759 $300 per pair
Mallory Dual point distributor $150 Aluminum trans adapter; Y-block to /?? see 3rd picture $100 Aluminum trans adapter; Y-block bellhousing pattern to 40s ford 3 speed $150 Also have the aluminum adapter that goes from the Ford 3 speed to a Muncie M series or T-10 $110
Boat 292 stuff Aluminum timing chain cover (Mercruiser) $50 Aluminum oil pan $200
Rick Cannon 650-739-9222 San Jose, CA
By 55blacktie - 6 Years Ago
You didn't post prices. Condition? Photos?
On the condition of the heads; if somebody seriously wants a specific casting number I'll pull them down, disassemble, hot tank and mag them. But they need to be serious as that is a fair amount of work. On the bellhousing picture. its for a Y-block but the transmission flange is odd. It seems to line up to a T-10/Muncie but the bolt holes in the bellhousing are smaller than those in the Muncie "ears".It also has an odd protruding flange around the opening for the trans front cover.
By PF Arcand - 6 Years Ago
This is likely a tough time to be advertising those items, (Covdid 19 & all) especially in their somewhat rough condition. You might want to at least power brush the heads enough for customers to get a reasonable look at them. Also, if your not in a rush to move the parts, U could advertise in Y-Block Magazine, published by-monthly, at a very reasonable .10 c / word, $3.00 minimum. @ PO. box 1005, Ottawa Illinois 61350 USA..(Editor is Bruce Young)
By 30 coupe - 6 Years Ago
Is the dist still for sale? If so do you have pictures of it? what is the condition of it? Thank You.
I'll take pictures of it.
