FS: Y-Block and Ford passenger car parts
http://forums.y-blocksforever.com/Topic152962.aspx
By blockhead2 - 5 Years Ago
See attachedhttp://forums.y-blocksforever.com/uploads/images/892746e6-d172-46ef-90c2-c7c8.jpg pix.
At the upper left:
  Tbird Heater duct, square, blower to plenum, NOS, original Ford. $35 (not current reproduction imitation)
  Tbird Heater duct, round, blower to fresh air duct, NOS, original Ford. $30 (not current reproduction imitation)
Below is dirty but unused 12 volt regulator. $25
Lower left:
  1 set of front suspension bushings (8). NOS, not the current repro. $65
To the right, 1955/57 double action Ford passenger car fuel pump (fuel filter bowl on the base). These are NOS with AC marked on top (for originality). $95
Also shown is a single action rebuilt fuel pump. $40
At the top: 1957 Distributor caps, $15 each, new, as made by Holley in the original Holley box. It was Holley that made the original Ford distributors.
To the right shown are Y-Block tappets, 16 NOS. The box is gone and the parts are a little grimy. These are not Chinese reproductions. $85.
Below is an NOS exhaust control valve. $80
1957 and up, V8 distributor points, rotor and condenser. $12 these are NOS but not necessarily by Ford. Some are loose.
1954-1956 V8 Y-Block distributor points, $4 each these are NOS but not necessarily by Ford. Some are loose.
1954-1956 V8 Y-Block distributor points, rotor and condenser. $10 these are NOS but not necessarily by Ford. Some are loose.
At the bottom is a rebuilt 1955 Ford Carburetor. Professionally restored and then run on an engine. $275 plus core.
At the top right is an NOS 1956 Ford distributor. This is equipped with dual points. $250
Next to that is a used 1957 Tbird tach drive distributor. $650
At the lower right is an NOS 1956 Ford door lock mechanism, RH. $175
Below that is an NOS two tooth sector shaft. $235
All prices are plus shipping.
Bill, wabateATverizonDotnet
By BamaBob - 5 Years Ago
PM sent.
