More Distributor
http://forums.y-blocksforever.com/Topic151430.aspx
By paul2748 - 6 Years Ago
How do you take off the top pieces of the distributor on the top, like the one on the bottom.  Press fit? I don't see any type of pin that holds it.  I want to swap parts
Added - These are 57-59 Distributorshttp://forums.y-blocksforever.com/uploads/images/b05358e6-182f-4a44-b1ee-ceaa.jpg
By oldcarmark - 6 Years Ago
In the Center of the upper Cam under the Lubrication felt should be a Clip. Holds the upper housing to Shaft.
Looking inside of the "tower" that the rotor goes on, I see two small wire like things sticking up.  Is this what you mean? I don't see a clip .  Push them together and the parts should release?  This is a 57-59 distributor
oldcarmark (4/21/2020)
That is the retainer  Wire "Clip". Spread the 2 ends slightly so it pulls off the Shaft. They are sometimes a "B" to get  off. Once its off the upper  parts will come off the Shaft. Small Needle nose pliers and small Screwdriver are useful. Watch the Clip doesn't fly away removing or installing.
By Barry L - 6 Years Ago
That's it, a circlip, I think they're called. Notorious for "flying" away when you try to lift it out. Keep a close watch on it.
