By junkyardjeff - 5 Years Ago
I am going to use a 55 272 with a 62 COM and flywheel so can I use the starter that came with the 272 and FOM or will I have to find a 62 starter.
By Ted - 5 Years Ago
Starters are the same from 1956 thru 1964 for the Y. 1954-1955 were six volt but otherwise the same. Even the 1958 thru 1964 starters for the FE engines will interchange with the Y starters.
I know the starter that came with the 272 works and not sure if its for 6 or 12 volts,I do have one from a 57 but its been laying in a shed since the early 70s.
By oldcarmark - 5 Years Ago
6 Volt Starters will work on 12 Volts and may last for Years depending on Starter Condition.
By darrell - 5 Years Ago
6 volt starters were a fix back when for hard starting in the winter.i dont know how much it helped
By Florida_Phil - 5 Years Ago
My 55 TBird was converted to 12 volts before I purchased it. It still has it's original 6 volt starter. It's been rebuilt at least once that I know of. I works just fine.
just had a 6volt apart,compared to 12volt the big diff is 12volt has a 3rd coil pack thats to slow the 12volt a bit,the rest is the same. the 3rd coil pack is wired direct to the power bar
